OBS Replay Buffer clips laggy/choppy
thatstimmy
Whenever I am playing a game or are on my desktop simply watching a video and I go to clip something it's extremely laggy/choppy. It's at like 1 FPS but the audio is perfectly fine.
If anyone can help me out so I can get it back to normal I would greatly appreciate it.
  • 2024-06-21 15-04-03.txt
rockbottom
Use faster Presets like P3 or P4, P7 ain't happening...
Remove one of the Display captures from this Scene.
- scene 'Scene':
15:04:08.389: - source: 'Monitors' (group)
15:04:08.390: - filter: 'Scaling/Aspect Ratio' (scale_filter)
15:04:08.390: - source: 'Secondary' (monitor_capture)
15:04:08.390: - source: 'Main' (monitor_capture)
Your audio is lagging real bad & needs to be addressed.
06:44:57.305: Max audio buffering reached!
06:44:57.305: adding 917 milliseconds of audio buffering, total audio buffering is now 960 milliseconds (source: Voice Chat)
06:44:57.305:
06:44:57.326: Source Voice Chat audio is lagging (over by 17936183.44 ms) at max audio buffering. Restarting source audio.
07:00:11.447: [ffmpeg muxer: 'Replay Buffer'] Wrote replay buffer to 'C:/Users/Timmy/Videos/!OBS/Instant Replay .mp4'
12:21:22.861: Source Desktop Audio audio is lagging (over by 1716806.07 ms) at max audio buffering. Restarting source audio.
12:32:06.424: Source Voice Chat audio is lagging (over by 18714682.09 ms) at max audio buffering. Restarting source audio.
thatstimmy
- scene 'Scene':
06:44:57.305:
Ahhh okay thank you I was wondering what I needed to change to get the audio to stop lagging. As for removing the secondary monitor I noticed that after I changed to the P4 preset everything seems fine... for now.
rockbottom
May need to work through the audio issues. If you look at the audio lag, mostly the Voice Chat. You're using Device Timing for Desktop Audio, the Voice Chat & VR. I would try Voice Chat & VR without using the Device Timing
15:04:08.320: [win-wasapi: 'Desktop Audio'] update settings:
15:04:08.320: device id: {0.0.0.00000000}.{359b8bb5-031d-4251-bbb5-54cd7500e563}
15:04:08.320: use device timing: 1
15:04:08.321: [Loaded global audio device]: 'Desktop Audio'
15:04:08.321: [win-wasapi: 'Voice Chat'] update settings:
15:04:08.321: device id: {0.0.0.00000000}.{b6075569-1362-4c1e-9608-daf297d6c388}
15:04:08.321: use device timing: 1
15:04:08.386: [win-wasapi: 'VR Headset'] update settings:
15:04:08.386: device id: {0.0.0.00000000}.{341fa4ea-840c-4f39-a6f3-6c306fd61947}
15:04:08.386: use device timing: 1
rockbottom
Having multiple Display, Game or Window captures in the same Scene can cause interference.
When you run the test, close/re-open OBS after you finish & upload the previous log so I have a complete log to look at.
thatstimmy
  • 2024-07-23 05-58-57.txt
rockbottom
Not many (any?) changes made & the log is truncated like the first one but I can see VR headset failed again.
05:58:58.930: [WASAPISource::TryInitialize]:[{0.0.0.00000000}.{341fa4ea-840c-4f39-a6f3-6c306fd61947}] Failed to enumerate device: 80070490
05:58:58.930: WASAPI: Device '{0.0.0.00000000}.{341fa4ea-840c-4f39-a6f3-6c306fd61947}' failed to start (source: VR Headset)
Be careful OBS was already running when you started.
5:58:57.222: ================================
05:58:57.222: Warning: OBS is already running!
05:58:57.222: ================================
05:58:57.222: User is now running multiple instances of OBS!
thatstimmy
VR Headset failed cause I still have it connected to my PC but it isn't on/active. I'm just not using it atm
