Question / Help OBS Screen flicker while local recording
laboy-leon
Trying to record Jedi Knights I and II; Jedi Academy/Outcast with Game Capture or with Windowed, the issue appears with both.
I keep getting an annoying screen flicker that won't go away. Anyone know what I should do to fix this?
My PC specs are:
Windows 10 64bit
FX-8320 4.00Ghz
16GB RAM
Radeon R9 380
Here is a very short video of the problem (Ignore the resolution change, I know what caused that)
https://youtu.be/_idMas86cCw
Here is my log:
22:23:03: CLR host plugin strings not found, dynamically loading 4 strings
22:23:03: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
22:23:03: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
22:23:03: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
22:23:03: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
22:23:03: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
22:23:04: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
22:23:04: CLRHost:: Could not find/load browser settings at location C:\Users\Felix\AppData\Roaming\OBS\pluginData\browser.json
22:23:04: CLRHost:: Exception: System.IO.FileNotFoundException: Could not find file 'C:\Users\Felix\AppData\Roaming\OBS\pluginData\browser.json'.
22:23:04: File name: 'C:\Users\Felix\AppData\Roaming\OBS\pluginData\browser.json'
22:23:04:    at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
22:23:04:    at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
22:23:04:    at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
22:23:04:    at CLRBrowserSourcePlugin.Shared.BrowserSettings.Reload()
22:23:04: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
22:23:50: No Intel graphics adapter visible in QSVHelper.exe, Optimus problem?
22:23:50: Failed loading CUDA dll
22:25:24: Open Broadcaster Software v0.657b - 64bit ( ^ω^)
22:25:24: -------------------------------
22:25:24: CPU Name: AMD FX(tm)-8320 Eight-Core Processor
22:25:24: CPU Speed: 4000MHz
22:25:24: Physical Memory:  16332MB Total, 13188MB Free
22:25:24: stepping id: 0, model 2, family 21, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 8, total cores 4
22:25:24: monitor 1: pos={0, 0}, size={1920, 1080}
22:25:24: Windows Version: 10.0 Build 10586 (revision 0)
22:25:24: Aero is Enabled
22:25:24: OBS Modules:
22:25:24: Base Address     Module
22:25:24: 0000000051530000 OBS.exe
22:25:24: 0000000012290000 OBSApi.dll
22:25:24: 0000000024890000 CLRHostPlugin.dll
22:25:24: 0000000023BA0000 DShowPlugin.dll
22:25:24: 0000000023FE0000 GraphicsCapture.dll
22:25:24: 0000000023CF0000 NoiseGate.dll
22:25:24: 0000000023A00000 PSVPlugin.dll
22:25:24: 000000001E710000 scenesw.dll
22:25:24: ------------------------------------------
22:25:24: Adapter 1
22:25:24:   Video Adapter: AMD Radeon (TM) R9 380 Series
22:25:24:   Video Adapter Dedicated Video Memory: 2124271616
22:25:24:   Video Adapter Shared System Memory: 4267864064
22:25:24:   Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
22:25:24: =====Stream Start: 2016-04-14, 22:25:24===============================================
22:25:24:   Multithreaded optimizations: On
22:25:24:   Base resolution: 1920x1080
22:25:24:   Output resolution: 1920x1080
22:25:24: Loading up D3D10 on AMD Radeon (TM) R9 380 Series (Adapter 1)...
22:25:24: Audio Format: 44100 Hz
22:25:24: Audio Channels: 2 Ch
22:25:24: Playback device Default
22:25:24: Using desktop audio input: Speakers (2- USB Advanced Audio Device)
22:25:24: Global Audio time adjust: 0
22:25:24: Using auxilary audio input: Yeti (2- USB Advanced Audio Device)
22:25:24: Mic time offset: 0
22:25:24: Audio Encoding: AAC
22:25:24:     bitrate: 192
22:25:24: Using graphics capture
22:25:24: Scene buffering time set to 700
22:25:24: x264: VBV maxrate specified, but no bufsize, ignored
22:25:24: Video Encoding: x264
22:25:24:     fps: 40
22:25:24:     width: 1920, height: 1080
22:25:24:     preset: veryfast
22:25:24:     profile: high
22:25:24:     keyint: 250
22:25:24:     CBR: no
22:25:24:     CFR: yes
22:25:24:     max bitrate: 64
22:25:24:     buffer size: 0
22:25:24:     quality: 10
22:25:25: Trying to hook process: OBS.exe
22:25:25: SharedTexCapture hooked
22:25:28: FlushBufferedVideo: Flushing 5 packets over 100 ms
22:25:28: Total frames encoded: 100, total frames duplicated: 0 (0.00%)
22:25:28: Total frames rendered: 129, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
22:25:28:
22:25:28: Profiler time results:
22:25:28:
22:25:28: ==============================================================
22:25:28: video thread frame - [100%] [avg time: 0.659 ms] [children: 21.7%] [unaccounted: 78.3%]
22:25:28: | scene->Preprocess - [0.303%] [avg time: 0.002 ms]
22:25:28: | GPU download and conversion - [21.4%] [avg time: 0.141 ms] [children: 19.3%] [unaccounted: 2.12%]
22:25:28: | | flush - [16.8%] [avg time: 0.111 ms]
22:25:28: | | CopyResource - [1.67%] [avg time: 0.011 ms]
22:25:28: | | conversion to 4:2:0 - [0.759%] [avg time: 0.005 ms]
22:25:28: Convert444Threads - [100%] [avg time: 1.101 ms] [children: 99.4%] [unaccounted: 0.636%]
22:25:28: | Convert444toNV12 - [99.4%] [avg time: 1.094 ms]
22:25:28: encoder thread frame - [100%] [avg time: 2.419 ms] [children: 0.496%] [unaccounted: 99.5%]
22:25:28: | sending stuff out - [0.496%] [avg time: 0.012 ms]
22:25:28:
22:25:28:
22:25:28: Profiler CPU results:
22:25:28:
22:25:28: video thread frame - [cpu time: avg 0.605 ms, total 78.125 ms] [avg calls per frame: 1]
22:25:28: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
22:25:28: | GPU download and conversion - [cpu time: avg 0.363 ms, total 46.875 ms] [avg calls per frame: 1]
22:25:28: | | flush - [cpu time: avg 0.121 ms, total 15.625 ms] [avg calls per frame: 1]
22:25:28: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
22:25:28: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
22:25:28: Convert444Threads - [cpu time: avg 1.464 ms, total 281.25 ms] [avg calls per frame: 2]
22:25:28: | Convert444toNV12 - [cpu time: avg 1.464 ms, total 281.25 ms] [avg calls per frame: 2]
22:25:28: encoder thread frame - [cpu time: avg 2.302 ms, total 218.75 ms] [avg calls per frame: 1]
22:25:28: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
22:25:28:
22:25:28: =====Stream End: 2016-04-14, 22:25:28=================================================
22:41:48: CLR host plugin instance deleted; removing dynamically loaded localization strings
22:41:48: Terminating 0x1b2c
Last game capture log:
2016-04-14, 22:25:25: we're booting up:
22:25:25: CaptureThread: attached to process OBS.exe
22:25:25: D3D9 Present
22:25:25: DXGI Present
22:25:25: (half life scientist) everything..  seems to be in order
22:25:25: DXGI: Found D3D 10
22:25:25: setting up d3d10 data
22:25:25: ---------------------- Cleared D3D10 Capture ----------------------
22:25:25: found dxgi format (dx10) of: 87, size: {632, 371}, multisampled: false
22:25:25: DoD3D10Hook: success
22:25:25: successfully capturing d3d10 frames via GPU
Thanks
  • 2016-04-14-2223-03.log
