OBS SETTINGS HELP PLS
albertgaming2
I have a i9-10900k and rtx 3080... i usualy play mafia bannerlord gta cs2 but idk why every setting i try it wont record smoothly in 4k 60fps... any help with some settings ? pls...
rockbottom
Those settings aren't what I would use but they won't cause stuttering. Look at your OBS log, most likely Rendering Lag in there & that's GPU overload.
rockbottom
Preset P5
Multipass qres
No B Frames
I'm assuming it's H265 you're recording but if it's H264, change Profile to High.
Xsoulsin
Have you attempted to lower in game quality or FPS and test. Lower in game settings and continue to test, you can make a game look great without losing a lot of performance hit, just have to find out what works for you.
rockbottom
Recordings will always stutter running that monitor @ 144. Set it @ 120 when using OBS.
Audio lag most likely caused by your surround headset.
Disable HAGS
23:46:47.059: Game Bar: On > Off
23:46:47.059: Game DVR: On > Off
Fix Scene & Scene 3, only 1 Display, Window, Game capture per.
23:46:48.775: Loaded scenes:
23:46:48.775: - scene 'Scene':
23:46:48.775: - source: 'Game Capture' (game_capture)
23:46:48.775: - source: 'Game Capture 4' (game_capture)
23:46:48.775: - source: 'Display Capture 2' (monitor_capture)
23:46:48.775: - source: 'Window Capture' (window_capture)
23:46:48.775: - source: 'Browser 7' (browser_source)
23:46:48.775: - source: 'Video Capture Device' (dshow_input)
23:46:48.775: - source: 'Image 2' (image_source)
23:46:48.775: - source: 'Image' (image_source)
23:46:48.775: - source: 'dono' (browser_source)
23:46:48.775: - source: 'subs' (browser_source)
23:46:48.775: - source: 'Image 3' (image_source)
23:46:48.775: - source: 'Browser 2' (browser_source)
23:46:48.775: - source: 'Browser 3' (browser_source)
23:46:48.775: - source: 'Browser' (browser_source)
23:46:48.775: - source: 'Browser 6' (browser_source)
23:46:48.775: - source: 'Browser 5' (browser_source)
23:46:48.775: - scene 'Scene 2':
23:46:48.775: - scene 'Scene 3':
23:46:48.775: - source: 'Game Capture 2' (game_capture)
23:46:48.775: - source: 'Game Capture 3' (game_capture)
23:46:48.775: - source: 'Display Capture' (monitor_capture)
23:46:48.775: - source: 'Game Capture 5' (game_capture)
