OBS stops recording at random
Marinijada
HI all maybe someone has had a similar experience or has an idea what might be causing OBS to stop recording at random times and no error...
I've tried recording for various lengths of time and found that OBS stopped without warning and no error messages at all.
I have attached some file logs where I've found no issue and have no idea why this would happen. The length of the recording is also random, from 33min to 58min so no rule there either. No hotkeys are defined either for any action so I hope someone ca give me some clue on this please.
Thank you in advance
  • 2021-11-28 17-59-04.txt
  • 2021-11-27 18-44-33.txt
  • 2021-11-27 18-00-01.txt
  • 2021-11-26 19-51-28.txt
You should check the Analizer
