Bug Report OBS-STUDIO 23.1.0 breaks V4L ?
darksurf
I just noticed If I install 23.0.1 , I can add a Source and Select V4L and add my webcam, but upgrading to 23.1.0 breaks that and I just get a black screen. After looking at my options to add a source, the V4L option is missing. Downgrading back to 23.0.1 fixes the issue. Anyone else experiencing this?
  • 2019-04-07 13-50-01.txt
Tuna
01:50:01 PM.981: os_dlopen(/usr//lib64/obs-plugins/linux-v4l2.so->/usr//lib64/obs-plugins/linux-v4l2.so): /usr//lib64/obs-plugins/linux-v4l2.so: undefined symbol: udev_new
01:50:01 PM.981:
01:50:01 PM.981: Module '/usr//lib64/obs-plugins/linux-v4l2.so' not loaded
Perhaps you need to install some udev library to make it work. I haven't followed the changes that may have happened to the plugin.
darksurf
01:50:01 PM.981:
You would think that, but reinstalling 23.0.1 , everything works fine.
Tuna
It depends on how both versions were build. The udev support is a compile time feature. Sits either missing or present. If present it requires libudev.
darksurf
Libudev is indeed installed. I'm running Sabayon Linux (Gentoo Based) and we use systemd and udev by default.
Tuna
So where do these OBS versions come from? Compiled yourself? From the Linux distro? Maybe it is a bug at their end?
Verify that these work:
$ ldd linux-v4l2.so | grep udev
    libudev.so.1 => /lib/x86_64-linux-gnu/libudev.so.1 (0x00007fd2a8cff000)
$ nm -D /lib/x86_64-linux-gnu/libudev.so | grep udev_new
000000000001a780 T udev_new
