OBS Studio Always Shows "Quit Unexpectedly" on Exit – Safe Mode Prompt on Reopen
GregTC
Hi everyone,
I’m encountering a persistent issue with OBS Studio on macOS 15.3 with OBS 31.0.1. Every time I close OBS—whether using Cmd + Q or through the menu—it gives the error message:
"OBS Studio quit unexpectedly."
Then, when I reopen it, I always get prompted to choose between opening OBS normally or in Safe Mode.
OBS itself runs fine while in use; this only happens when closing it.
Troubleshooting Steps I've Tried (No Success):​
Updated macOS and OBS to the latest versions
Disabled Browser Source Hardware Acceleration
Reset OBS settings by renaming ~/Library/Application Support/obs-studio/
Fully uninstalled & reinstalled OBS, including manually deleting all related files
Checked macOS permissions (OBS has Full Disk Access)
Tried running in Safe Mode (same behavior as normal mode)
Checked logs in Terminal (OBS runs fine until exit)
The crash report suggests an issue related to Chromium Embedded Framework (CEF). Has anyone else encountered this on macOS 15.3? Any other ideas on how to fix it?
Translated Report (Full Report Below)
Process: OBS [1884]
Path: /Applications/OBS.app/Contents/MacOS/OBS
Identifier: com.obsproject.obs-studio
Version: 31.0.1 (12846547662)
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2025-02-03 10:08:54.1731 +0000
OS Version: macOS 15.3 (24D60)
Report Version: 12
Bridge OS Version: 9.3 (22P3051)
Anonymous UUID: 19373D99-4FE6-8DD6-A158-895FC55167AF
Time Awake Since Boot: 980 seconds
System Integrity Protection: enabled
Crashed Thread: 0 CrBrowserMain Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes: 0x0000000000000001, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [1884]
VM Region Info: 0 is not in any region. Bytes before following region: 4313931776
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 101216000-10164c000 [ 4312K] r-x/r-x SM=COW /Applications/OBS.app/Contents/MacOS/OBS
Kernel Triage:
VM - (arg = 0x3) mach_vm_allocate_kernel failed within call to vm_map_enter
Thanks in advance!
saved_92
I've had the same problem for over a week. I've tried downloading a previous version and I get the same errors.
AaronD
Put a logfile into our automated Analyzer. (link in my signature) See what it comes up with.
One common source of crashes is a bad plugin. One of the well-advertised ones is well-known on these forums to be poorly written.
rockbottom
I searched this & it may be caused by another app.
heavymcd
I'm getting this same issue on an M1 Max Mac Studio, macOS 15.3.1, and OBS 31.0.1.
I've literally done a full "transfer this computer" wipe of the system, the only thing I re-installed was OBS straight off the website, still get it. Zero plugins, zero profiles/scenes setup, and not a single other application installed on the entire computer that didn't come preinstalled from Apple.
EvanLN
It’s the same issue on my M2 MacBook, but only when the ‘YouTube live control panel’ dock is used. If not, no crash.
todahnyc
This really seems to be the issue, I've disabled YouTube live control panel from Docks within OBS and this annoying message finally stopped.
GregTC
Just tested removing the YouTube dock and open closed a few times, and it seems not to cause the issue. It's good to get rid of the error, but it is also useful to have the YouTube dock.
Langjjj
Did all the uninstalls and restarts without solving the crash. Definitely the "YouTube Live Control Panel" – when disabled OBS shuts down normally. Thanks for sharing.
soveda
This has been driving me crazy, thank you this fixed things!
NickB2357
Came back to report - closing (removing) the YouTube control dock from OBS stopped the error upon closing the app for me.
djdeity
I don't have a YT Control Dock at all, and I'm getting the "Quit Unexpectedly" error over and over.
MacBook Pro - Intel - Mac OS Ventura
mlinjector
I’ve been running into the exact same issue on macOS 15.3 with OBS 31.0.1, works fine during use but always crashes on quit with the Safe Mode prompt on restart. From what I’ve read it seems tied to the Chromium Embedded Framework, so it might need a patch from OBS devs. You’re not the only one seeing this.
