OBS Studio can't hold consistent 60FPS while RECORDING
moralesofc
I noticied my 1080p60 videos not smoother like I want, Idk why.
My PC setup is:
Ryzen 5 3600
GTX 1660
16GB Ram 3200mhz
Motherboard AB350M Gigabyte
I've tested alot of settings for recording, but all my videos are not smoother like I want to.
Sometimes I feel fps dropping to 48/50, but my FPS in game is fine, always above 250.
I have a 60Hz monitor, but I overclocked it to 75hz (4x3 res) and 74Hz 1080p.
I already tested using all res in 60hz, but the result is the same.
*I always open OBS as admin*
Here is a video using OBS Sudio 1080p60 settings: https://www.youtube.com/watch?v=4YBC_W7_drY
Here is my video using OBS Studio 1080p60 settings: https://www.youtube.com/watch?v=Q45gKAtRUQ0
(my Premiere render is 1440p to get vp09 codec)
  • 2020-08-14 04-26-11.txt
rockbottom
Limit in game framerate to 120Mhz
Get rid of your shitty "Overclock" & set monitor back to 60Mhz
Change Color Range from Full to Partial
Look at this thread for an explanation.
Turn off HDR if you have it on.
You have a Scene with Game & Monitor Capture, create another Scene & move one of them to it.
Record w/CQP, CBR is for streaming. Try these settings first & if there is no dropped frames, try the High Quality Preset.
Lower CQ Levels will produce higher quality/larger files. Higher CQ Levels the opposite.
moralesofc
I already back to 60hz, changed Full to Partial, I tested CQP exactly like ur screenshot and the final result is the same.
rockbottom
I gotta run but since you're running the newest version of Windows, make sure HAGS is disabled. I'll check back later.
