OBS STUDIO randomly gets not responding and stops the streaming.-
erniequintero
Hi, I start having random OBS Studion not responding while streaming.
I gather the logs but not sure what to look for to get the right point to view and fix it.
I hope someone can take a look on my logs and see if there is anything that could cause it.
Also I have lionardboard not sure if there is something related to that.
I see a lot of obs-browser[4]: CONSOLE: %cFFZ [%csocket%c]:%c (source: https://cdn.frankerfacez.com/static/avalon.af32d385c996090509c9.js:2)
Latest logs
Crash Report
  • 2021-01-27 19-52-11.txt
  • 2021-01-27 21-08-38.txt
  • 2021-01-28 11-01-29.txt
  • 2021-01-28 11-02-40.txt
  • 2021-01-28 11-05-47.txt
ATs_fm
Getting the same error. Must have something to do with FrankerFaceZ or BetterTTV emotes. Some browser source seems to be not loading propperly, can't figure out the exact problem though... :/
ATs_fm
This error might also be tied to the websocket plugin... maybe?
(your error:
11:16:29.376: obs-browser[4]: CONSOLE: WebSocket connection to 'wss://lilz.frankerfacez.com/' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR (source: https://cdn.frankerfacez.com/static/avalon.af32d385c996090509c9.js:2)
(my error:
01:59:38.836: obs-browser[4]: CONSOLE: WebSocket connection to 'wss://yoohoo.frankerfacez.com/' failed: Error in connection establishment: net::ERR_CONNECTION_RESET (source: https://cdn.frankerfacez.com/static/avalon.c8d994a73c65dc9577b8.js:2)
Raynsauce
Yeah seems to be definately an issue with the websockets plugin (as of v4.9).
Maybe a future update of the plugin will fix this issue.
Unfortunately still not fixed, no issues when browser-source isn't being used. Shame it's automatic when you switch Stream services, but a workaround, using FF/Chrome and capturing the window works without crashing
