Question / Help OBS Stuttering in Preview/Recording/Stream
TheGodlyNoob
Hey,
So I recently changed to a new PC ( i9 9900k + 2080 ti ) from my old PC ( i7 8700k & 1080 ti ) and now I have issues.
I use the exact same settings ( same scenes, same everything ) on the new PC as the old one. I tried locking my frames in game to less frames than my old one and I still get the issue. Tried the new NVENC/old NVENC still, issue persists. Tried multiple GPU drivers. Disabled every windows crap.
Games I play are pretty much Apex and Rainbow Six Siege. But mostly Rainbow Six Siege and I get the issue in both games.
Clearly the new PC should be fine getting more frames + recording but it's quite the opposite.
I thought at first it would be because of Window's issue where if you have monitors with different refresh rates, OBS fucks up but I never had this issue on the old PC with the exact same setup and well.. I unplugged my "2nd monitor" and the issue was still there so that's out of the equation.
My frames are limited to 144 fps on Apex ( I can easily run over 240-300 FPS in Apex before they fixed the frames to 144 by accident last patch ) and I still get the issue. So the GPU shouldn't be overloaded since it's working wayyyy less than it can do.
Not quite sure what to do anymore.
Log file : https://obsproject.com/logs/u1qAdFO0V-zw33fS
Spiriitus
I was getting these same exact symptoms on a 9600k @ 5.2GHz + RTX 2070 oc'd. Just now tried deleting my game capture and swapped for window capture. Seems to be a lot less choppy recordings coming from NVENC (new). I'll continue testing and update. Curious to hear if it helps with you.
Spiriitus
Also take a look at your resource usage in task manager while recording and gaming to see if anything is reaching the 90-100% range.
carlmmii
OP has 2% frames lost due to rendering lag, which is also causing the 2% frames lost in encoding. Try turning off Psycho Visual Tuning, as this adds requires extra GPU resources for encoding.
r23r23
Hey,
i have the exect same issue like down to the game i just got new parts and its all of a sudden lagging did u find a fix
