Question / Help OBS will not work on Intel HD Graphics (Ironlake)
FyreTyphoon
Hi, I have an Asus K52F laptop that I use to stream every once in a while. It has an Intel Pentium p6200 (I know, weak.) 6gb of memory, 650gb hard disk, and Ironlake Intel HD Graphics, and it's OS is Windows 7 pro x64. It used to work just fine, but now it suddenly claims that directx 10 is unsupported even though this particular graphics chipset supports that instruction set just fine. What should I do? Nothing seems to solve it, not even newer drivers, modded drivers, etc. Thanks.
Here's a log file:
21:09:03: Open Broadcaster Software v0.59b - 32bit (´・ω・`)
21:09:03: -------------------------------
21:09:03: CPU Name: Intel(R) Pentium(R) CPU P6200 @ 2.13GHz
21:09:03: CPU Speed: 2128MHz
21:09:03: Physical Memory: 4095MB Total, 4095MB Free
21:09:03: stepping id: 5, model 37, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 2, total cores 2
21:09:03: monitor 1: pos={0, 0}, size={1366, 768}
21:09:03: Windows Version: 6.1 Build 7601 S
21:09:03: Aero is Enabled
21:09:03: OBS Modules:
21:09:03: Base Address Module
21:09:03: 011F0000 OBS.exe
21:09:03: 65BA0000 OBSApi.dll
21:09:03: 69510000 DShowPlugin.dll
21:09:03: 6AB60000 GraphicsCapture.dll
21:09:03: 694F0000 NoiseGate.dll
21:09:03: 694D0000 PSVPlugin.dll
21:09:03: ------------------------------------------
21:09:03: Adapter 1
21:09:03: Video Adapter: Intel(R) HD Graphics Modded
21:09:03: Video Adapter Dedicated Video Memory: 134217728
21:09:03: Video Adapter Shared System Memory: 1711276032
21:09:03: Video Adapter Output 1: pos={0, 0}, size={1366, 768}, attached=true
21:09:03: =====Stream Start: 2016-05-13, 21:09:03===============================================
21:09:03: Multithreaded optimizations: On
21:09:03: Base resolution: 1366x768
21:09:03: Output resolution: 1364x768
21:09:03: Loading up D3D10 on Intel(R) HD Graphics Modded...
Error: Could not initialize DirectX 10 on Intel(R) HD Graphics Modded. This error can happen for one of the following reasons:
1.) Your GPU is not supported (DirectX 10 is required - note that many integrated laptop GPUs do not support DX10)
2.) You're running Windows Vista without the "Platform Update"
3.) Your video card drivers are out of date
If you are using a laptop with NVIDIA Optimus or AMD Switchable Graphics, make sure OBS is set to run on the high performance GPU in your driver settings.
Harold
It requires HARDWARE support for 10.1, not just 10.0
And the procesor is definitely too weak.
FyreTyphoon
Well, I was planning on breathing a bit of new life into it by upgrading the microprocessor to an i5-540m.would that help at all?
