OBS with NDI is getting stuck
xandru
I am using vmix with a Blackmagic decklink input from a camera and keying the background and using NDI to send the output with alpha channel to OBS so that I can add a background and stream it. This is all happening in one pc. But for some reason it seams like NDI keeps on closing the application and shows a popup saying "whoops, OBS has crashed". I am also using OBS in portable mode so I can open multiple instances of OBS. Thanks
  • Crash 2024-05-09 09-21-15.txt
subnoize
I am using NDI v6 with alpha channels in OBS no problem. You might need to grab your OBS crash report and post that for the devs to give a better response.
xandru
Hi and which version of obs and ndi are you using ?
Thanks
