Please any help (Quick Sync)
Jkingstan
Jkingstan
This is an example of a "Blurry" image at 57:26
qhobbes
Set your Keyframes and B frames to 2.
Your log contains streaming sessions with dropped frames. This can only be caused by a failure in your internet connection or your networking hardware. It is not caused by OBS. Follow the troubleshooting steps at: Dropped Frames and General Connection Issues.
were491
maybe it could be due to a downscale/upscaling. try running the game at the exact same resolution that you stream at, and/or try using a 'higher' downscale filter (lanczos)
