PLEASE HELP!!! SERIOUS ISSUES!! Preview full screen issues
bswishhh
PLEASE! someone help! i am having a huge proplem with obs! When i click on preview full screen it goes either to dark screen with wonky colors or it goes to grey! also the mouse cursor has some knarly trailing behind it. Sometimes i can even color in the whole screen with the trail os the cursor. WHAT DID I DO??? Someone please help! thanks for any advice! i already comletely uninstalled the program and still no change. I am running a dual monitor setup and i am using an elgato HD60s
bswishhh
01:07:45.348: CoInitializeEx succeeded: 0x00000001
01:07:45.349: CPU Name: Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz
01:07:45.349: CPU Speed: 2592MHz
01:07:45.349: Physical Cores: 6, Logical Cores: 12
01:07:45.349: Physical Memory: 16146MB Total, 10384MB Free
01:07:45.349: Windows Version: 10.0 Build 19041 (release: 2004; revision: 508; 64-bit)
01:07:45.349: Running as administrator: false
01:07:45.349: Aero is Enabled (Aero is always on for windows 8 and above)
01:07:45.349: Windows 10 Gaming Features:
01:07:45.349: Game Bar: Off
01:07:45.349: Game DVR: Off
01:07:45.349: Game DVR Background Recording: Off
01:07:45.349: Game Mode: Off
01:07:45.351: Sec. Software Status:
01:07:45.358: Microsoft Defender Antivirus: enabled (AV)
01:07:45.359: Windows Firewall: enabled (FW)
01:07:45.359: Current Date/Time: 2020-09-12, 01:07:45
01:07:45.359: Browser Hardware Acceleration: true
01:07:45.359: Portable mode: false
01:07:45.762: OBS 25.0.8 (64-bit, windows)
01:07:45.762: ---------------------------------
01:07:45.788: ---------------------------------
01:07:45.788: audio settings reset:
01:07:45.788: samples per sec: 44100
01:07:45.788: speakers: 2
01:07:45.790: ---------------------------------
01:07:45.790: Initializing D3D11...
01:07:45.790: Available Video Adapters:
01:07:45.793: Adapter 0: NVIDIA GeForce RTX 2070 Super
01:07:45.793: Dedicated VRAM: 4105175040
01:07:45.793: Shared VRAM: 4170196992
01:07:45.793: PCI ID: 10de:1e91
01:07:45.793: Driver Version: 27.21.14.5206
01:07:45.793: output 0: pos={0, 0}, size={1920, 1080}, attached=true, refresh=300, name=
01:07:45.793: Adapter 1: Intel(R) UHD Graphics
01:07:45.793: Dedicated VRAM: 134217728
01:07:45.793: PCI ID: 8086:9bc4
01:07:45.793: Driver Version: 26.20.100.7985
01:07:45.795: Loading up D3D11 on adapter NVIDIA GeForce RTX 2070 Super (0)
01:07:45.861: D3D11 loaded successfully, feature level used: b000
01:07:45.861: DXGI increase maximum frame latency success
01:07:45.861: D3D11 GPU priority setup failed (not admin?)
01:07:46.223: ---------------------------------
01:07:46.223: video settings reset:
01:07:46.223: base resolution: 1920x1080
01:07:46.223: output resolution: 1280x720
01:07:46.223: downscale filter: Bicubic
01:07:46.223: fps: 30/1
01:07:46.223: format: NV12
01:07:46.223: YUV mode: 601/Partial
01:07:46.223: NV12 texture support enabled
01:07:46.224: Audio monitoring device:
01:07:46.224: name: Default
01:07:46.224: id: default
01:07:46.224: ---------------------------------
01:07:46.227: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
01:07:46.228: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
01:07:46.273: [AMF] Unable to load 'amfrt64.dll', error code 126.
01:07:46.275: [AMF] AMF Test failed due to one or more errors.
01:07:46.275: Failed to initialize module 'enc-amf.dll'
01:07:46.297: [obs-browser]: Version 2.8.6
01:07:46.350: NVENC supported
01:07:46.606: VLC found, VLC video source enabled
01:07:46.615: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
01:07:46.616: No blackmagic support
01:07:46.630: ---------------------------------
01:07:46.630: Loaded Modules:
01:07:46.630: win-wasapi.dll
01:07:46.630: win-mf.dll
01:07:46.630: win-dshow.dll
01:07:46.630: win-decklink.dll
01:07:46.630: win-capture.dll
01:07:46.630: vlc-video.dll
01:07:46.630: text-freetype2.dll
01:07:46.630: rtmp-services.dll
01:07:46.630: obs-x264.dll
01:07:46.630: obs-vst.dll
01:07:46.630: obs-transitions.dll
01:07:46.630: obs-text.dll
01:07:46.630: obs-qsv11.dll
01:07:46.630: obs-outputs.dll
01:07:46.630: obs-filters.dll
01:07:46.630: obs-ffmpeg.dll
01:07:46.630: obs-browser.dll
01:07:46.630: image-source.dll
01:07:46.630: frontend-tools.dll
01:07:46.630: enc-amf.dll
01:07:46.630: decklink-ouput-ui.dll
01:07:46.630: coreaudio-encoder.dll
01:07:46.630: ==== Startup complete ===============================================
01:07:46.630: Service '' not found
01:07:46.635: No scene file found, creating default scene
01:07:46.636: All scene data cleared
01:07:46.636: ------------------------------------------------
01:07:46.762: WASAPI: Device 'Speakers (Realtek(R) Audio)' [48000 Hz] initialized
01:07:46.795: WASAPI: Device 'Microphone (LCS USB Audio)' [48000 Hz] initialized
01:07:46.795: Switched to scene 'Scene'
01:07:46.795: Failed to glob scene collections
01:07:46.842: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds (source: Mic/Aux)
01:07:46.842:
01:07:47.206: [rtmp-services plugin] Successfully updated file 'services.json' (version 145)
01:07:47.206: [rtmp-services plugin] Successfully updated package (version 145)
01:09:09.570: User added source 'Video Capture Device' (dshow_input) to scene 'Scene'
01:09:09.577: Video Capture Device: DecodeDeviceId failed
01:09:09.577: Video Capture Device: Video configuration failed
01:09:10.537: ---------------------------------
01:09:10.537: [DShow Device: 'Video Capture Device'] settings updated:
01:09:10.537: video device: HD Pro Webcam C920
01:09:10.537: video path: \\?\usb#vid_046d&pid_0892&mi_00#8&1f83f743&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
01:09:10.537: resolution: 640x480
01:09:10.537: flip: 0
01:09:10.537: fps: 30.00 (interval: 333333)
01:09:10.537: format: YUY2
01:10:12.592: ---------------------------------
01:10:12.592: [DShow Device: 'Video Capture Device'] settings updated:
01:10:12.592: video device: HD Pro Webcam C920
01:10:12.592: video path: \\?\usb#vid_046d&pid_0892&mi_00#8&1f83f743&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
01:10:12.592: resolution: 640x480
01:10:12.592: flip: 0
01:10:12.592: fps: 30.00 (interval: 333333)
01:10:12.592: format: YUY2
01:10:13.941: ---------------------------------
01:10:13.941: [DShow Device: 'Video Capture Device'] settings updated:
01:10:13.941: video device: HD Pro Webcam C920
01:10:13.941: video path: \\?\usb#vid_046d&pid_0892&mi_00#8&1f83f743&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
01:10:13.941: resolution: 640x480
01:10:13.941: flip: 0
01:10:13.941: fps: 30.00 (interval: 333333)
01:10:13.941: format: YUY2
01:10:19.852: User Removed source 'Video Capture Device' (dshow_input) from scene 'Scene'
01:10:24.238: User added source 'Display Capture' (monitor_capture) to scene 'Scene'
01:10:31.949: [jim-nvenc: 'simple_h264_stream'] settings:
01:10:31.949: rate_control: CBR
01:10:31.949: bitrate: 2500
01:10:31.949: cqp: 20
01:10:31.949: keyint: 250
01:10:31.949: preset: hq
01:10:31.949: profile: high
01:10:31.949: width: 1280
01:10:31.949: height: 720
01:10:31.949: 2-pass: false
01:10:31.949: b-frames: 2
01:10:31.949: lookahead: false
01:10:31.949: psycho_aq: true
01:10:31.949:
01:10:31.955: ---------------------------------
01:10:31.955: [FFmpeg aac encoder: 'simple_aac'] bitrate: 160, channels: 2, channel_layout: 3
01:10:31.955:
01:10:31.976: ==== Recording Start ===============================================
01:10:31.976: [ffmpeg muxer: 'simple_file_output'] Writing file 'C:/Users/bswis/Videos/2020-09-12 01-10-31.mkv'...
01:10:35.965: [ffmpeg muxer: 'simple_file_output'] Output of file 'C:/Users/bswis/Videos/2020-09-12 01-10-31.mkv' stopped
01:10:35.965: Output 'simple_file_output': stopping
01:10:35.965: Output 'simple_file_output': Total frames output: 111
01:10:35.965: Output 'simple_file_output': Total drawn frames: 120
01:10:35.965: ==== Recording Stop ================================================
01:10:36.000: warning: 2 frames left in the queue on closing
01:11:07.698: [jim-nvenc: 'simple_h264_stream'] settings:
01:11:07.698: rate_control: CBR
01:11:07.698: bitrate: 2500
01:11:07.698: cqp: 20
01:11:07.698: keyint: 250
01:11:07.698: preset: hq
01:11:07.698: profile: high
01:11:07.698: width: 1280
01:11:07.698: height: 720
01:11:07.698: 2-pass: false
01:11:07.698: b-frames: 2
01:11:07.698: lookahead: false
01:11:07.698: psycho_aq: true
01:11:07.698:
01:11:07.704: ---------------------------------
01:11:07.704: [FFmpeg aac encoder: 'simple_aac'] bitrate: 160, channels: 2, channel_layout: 3
01:11:07.704:
01:11:07.710: ==== Recording Start ===============================================
01:11:07.710: [ffmpeg muxer: 'simple_file_output'] Writing file 'C:/Users/bswis/Videos/2020-09-12 01-11-07.mkv'...
01:11:13.598: [ffmpeg muxer: 'simple_file_output'] Output of file 'C:/Users/bswis/Videos/2020-09-12 01-11-07.mkv' stopped
01:11:13.599: Output 'simple_file_output': stopping
01:11:13.599: Output 'simple_file_output': Total frames output: 168
01:11:13.599: Output 'simple_file_output': Total drawn frames: 177
01:11:13.599: ==== Recording Stop ================================================
01:11:13.637: warning: 2 frames left in the queue on closing
