Question / Help Poor Stream Quality! (Details inside)
Qoou
I have been streaming on and off for a couple of years now. I only have a small viewer base of friends because of my poor stream quality.
My PC/OBS/Internet Specs:
  • i7 4790k (OC'd to 4.5GHz)
  • GTX 760
  • 60MBps/4MBps Speed Resultstest
  • 1920x1080x Resolution(Have tried all the way down to 480)
  • 2200 Bitrate (have tried 1300-3500)
  • 30fps
  • Also streaming to the closest location to me (US: Ashburn, VA)
Other info: The computer uses about 30%-50% CPU low temps while streaming. The games run at max fps on my screen, usually 90-180 depending on the game. I have no lag or distortion at all on my end. Also, I recorded at the same time I was streaming and the recording was absolutely perfect with no distortion.
Here is a quick clip to show what I am talking about. https://www.twitch.tv/qoou123/v/75557031
Watch around the 20-35 second area to really see the problem. In WoW it is bearable to watch, but if I play a FPS it is impossible to watch.
I thought maybe it was because the bandwidth may be limited for streamers with low views, so I went to the botton of the WoW players streaming list, and even people playing with 0 views had crystal clear quality.
Any help is appreciated! Thank you!
OBS log: http://pastebin.com/2EeJDbaR
  • 2016-07-01-0107-51.log
Sapiens
Looks about right for your settings. Stop trying to stream high motion games at 1080p. Downscale to 720p, enable vsync or cap your FPS at something reasonable, use a more demanding preset if your CPU can handle it.
Qoou
I'll try caping the FPS. But like I said it still looks just as bad when I stream at 720p. And when playing a FPS like CS:GO, the screen just freezes and jumps around.
