Question / Help Possibility to Stream?
ZeroSkye
Hello community! I'm wondering if it's possible for me to stream games using a wireless internet connection. If there are any specific things you all need to know, just ask in the comments. Thank you and have a nice day/night.
CPU: Intel Core i5-3570K 3.4GHz
GPU: Nvidia GTX 660
RAM: 8 GB
  • 2016-09-12-1428-14.log
alpinlol
Your Log is incomplete, but why would it not be working? As long as the Connection to your Wifi is stable you should be able to stream.
ZeroSkye
When I streamed on Facebook, viewers say that the stream is skipping frames. Also how would I be able to get a complete log?
ZeroSkye
How should I explain this. I live in a house that's divided into 2 houses. The first house is on the left and the the second is on the right. The whole router that runs the wifi for both houses in house 1. I live in house 2 and the furthest away from the router.
alpinlol
Well your Hardware is enough to stream 720p30 with on veryfast Preset but if you want to stream you really have to adjust your Bitrate because 19000 Bitrate is literally getting you banned on the fly.
I would suggest staying around 2000-2500 Bitrate if you are a non Partner.
Tho if you are trying to RECORD then your settings will obviously be different.
