Question / Help PS4 Audio sync issues w/ Elgato HD60s
fornatron
Im finding I have random audio sync issues. It can happen 3 hours into my stream or after 30 minutes. I also find that OBS causes my macs fans to run full throttle as soon as I launch it. I reseated cables, I also heard toggling RGB settings on PS4 helps (it did not).
Here is my setup
PS4 - HD60s - MacBook Pro 16" 8 core i9, 16GB RAM , AMD Radeon Pro 5500M
The audio from my USB mic is always in sync. Its just the audio coming from HDMI into my HD60s.
Attached are my log files.
Any suggestions would be appreciated!
  • 2020-05-06 19-29-25.txt
  • 2020-05-06 18-15-27.txt
