random stuttering
Marc304
Hi,
I have been trying to fix a stuttering problem for a while now.
Here is a video of it: https://youtu.be/aR8bsv2BJUQ?t=609
The stats display shows no frame drops
I tried to
- disable/enable game mode
- clean install Nvidia drivers and OBS
- high process priority
- run as admin
- use CBR and VBR
- run game at 60hz (and cap game to 60fps)
- Disable G-Sync
What could I try next? Is there anything unusual in the log?
My System:
RTX 2060 (using nvenc)
Ryzen 7 3700x
16 GB DDR4 3000Mhz RAM
400k download 200k Upload (streaming with 9-12k Bitrate)
  • 2020-11-30 22-38-14.txt
Marc304
22:38:14.847: output 0: pos={0, 0}, size={1920, 1080}, attached=true, refresh=144, name=Acer XB241H
try to set the display refresh rate direct in windows to 120hz
energy setting in windows to hight ?
and make a stream of 5 minutes then send a log so we have more informations
Thank you for the reply. I tried to change my screen to 120hz and set the Windows and Nvidia power settings to high.
The stuttering is still there, but I think it's a bit better. Its appearing more frequently but it don’t last that long.
I also tried it at 60hz (https://youtu.be/Sr548CfrawY?t=256), but I didn't see any difference.
Is there anything else I can try?
(Ignore the “attempting to hook process” in the 60fps log, I tested something before I started the Stream)
  • 60fps.txt
  • 120fps.txt
