Recording freezes frequently on long recording sessions.
GandraXD
So i want to speedrun Resident Evil 3 and when i try to record a run which usually lasts for about a 50-60mins my recording freezes for random amounts of time but audio continues. When i was doing test recording that last about 5 mins everything was working fine as intended. How do i fix this, im quite new to recording my game so any kinda help would be much appreciated.
Log: https://obsproject.com/logs/aw8Oyv39VM_tIwOw
  • 2021-12-13 14-07-03.txt
iampaul002
Follow these steps, I hope I can serve you.
Press the Start key and type the word CMD, right click on the command prompt and select Run as administrator, enter the following commands one by one followed by the Enter key:
sfc /SCANNOW
DISM.exe / Online / Cleanup-image / Scanhealth
DISM.exe / Online / Cleanup-image / Restorehealth
The execution of these processes may be delayed, do not forget to restart the computer to apply changes.
If it works, follow these others.
Any corrupt DLL files are best performed using built in utilities or using a repair upgrade method:
Open Start, type: CMD
Right click CMD
Click Run as administrator
Type in at the prompt OR Copy and Paste these one at a time : (Hit enter after each)
Dism /Online /Cleanup-Image /CheckHealth
Dism /Online /Cleanup-Image /ScanHealth
Dism /Online /Cleanup-Image /RestoreHealth
Also run the System File Checker utility:
Right click CMD
At the Command Prompt, type: sfc/scannow
This will check for any integrity violations
Restart your system
