Recording Notification
Recording Notification 2.0
Tobsa
Tobsa submitted a new resource:
Recording Notification - A popup window that notifies you when OBS is recording
How it works:
When the 'Start recording' button is pressed a popup window appears
on top of the screen showing you that OBS is recording,
you can left-click and drag the window to position it.
This script was made using Python and tkinter library.
Installation:
  • Download the python-3.6.8-embed-amd64.rar that includes a Python compatible package with the necessary libraries.
  • Open OBS and go to - Tools...
Tobsa
Tobsa updated Recording Notification with a new update entry:
v1.2
How it works:
When the 'Start recording' button is pressed a popup window appears on top of the screen showing you that OBS is recording You can left-click and drag the window to position it. This script was made using Python and tkinter library.
Features:
  • You can enable or disable the Timer in the...
Hi can you please update this , as new vertical recording plugin as been introduced in obs
(by aitum - https://aitum.tv/download/vertical/)
, the script does not notifies me when i am recoding vertically, only when i am doing it horizontally.
ALso if you can keep the colour of vertical recording notification a little different like yellow colour dot , instead of red colour which is colour of dot for horizontal recording, it will also be super helpful.
