Question / Help Recording totally corrupted (pink and green)
Xarthangrol
Hello forum,
I just installed OBS on Manjaro.
After getting the screen capture to work, I started the recording without any problems, but when I play back the recording, it is bright pink and green with what looks like 'ghosts' of file directories. I don't have Thunar running, so I'm not sure where it is getting the input from. I do have VIM running, but the window capture is targeting this forum page on Chromium not Vim (OBSTargetWindowCapture.png).
I've included a log.
The two files showing the corrupted recording are what the recording flips between for the duration.
I'm using the free NVidia drivers not the proprietary ones, which are what I had when I used OBS before a system reinstall.
Any help would be appreciated. Thank you.
  • 2017-11-03 17-52-44.txt
