D
Deleted member 340745
Hi I’m new here and also quite new to OBS (although I learned quite a lot for the past few days). So please tell me when I’m doing something wrong here.
I’ve got a problem with the Replay Buffer:
I have set that when I press the hotkey, it should safe the past 20 seconds. Max memorie use is 512mb. I use a MacBook Pro mid 2015 with the extra AMD Radeon R9 M370X and a i7-4870HQ. However, it just keeps saving from the moment when I pushed the “start replay buffer” button. Therefore I got minutes of saved videos instead of the 20 seconds I have set. It sounds like a bug in OBS studio 27.0.1 (the version I’m using). Does anyone know if I can fix it, or can I report this to the developers, so it will be fixed in the next update?
This is how I do it:
Am I doing something wrong or is it bugged?
Thanks in advance!
!!!IMPORTANT!!! - LOG FILE HERE: https://obsproject.com/logs/at9X2nB0hTvdfDrR
I also made a short video to describe the problem. If there is still anything not clear, let me know!
You can find the video here: https://drive.google.com/file/d/1WiEXcPXTzQXTYE7wDTuAq0r7xmIBZb1i/view?usp=sharing
I’ll put screenshots of the settings I use in OBS below:
- I starts obs
- Deleted the black screen source and add “display capture”
- I press “;” to start replay buffer.
- I wait a minute (approximately)
- I press “\” to safe
- It says that it’s saved
- I press “'” to stop replay buffer
- I close obs
- Now it should save the past 20 seconds right? Well in this case, I got a video of 1 minute and 53 seconds
Thanks in advance!
