Resource icon
RGB levels 2020-05-20
Lyndondr
Has anyone been able to make this work in Windows? Where does the .so file go? I assume one of the .ini file need to be changed too?
javierdiazm
Hey there, I am haveing trouble building it on ubuntu 18.04 and obs-studio-26.1.2
I have successfully built obs
then i cloned obs-rgb-levels-filter from github, created the build directory and executed cmake like this:
javier@Bullet:~/Projects/OBS26/obs-rgb-levels-filter/build$ cmake -DOBS_SRC_DIR=../../obs-studio-26.1.2 -DLIBOBS_LIB=../../obs-studio-26.1.2/libobs -DCMAKE_INSTALL_PREFIX=/usr -DUSE_UBUNTU_FIX=true ..
-- The C compiler identification is GNU 7.5.0
-- The CXX compiler identification is GNU 7.5.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Found Libobs: /home/javier/Projects/OBS26/obs-studio-26.1.2/libobs
CMake Error at external/FindLibObs.cmake:98 (include):
include could not find load file:
../../obs-studio-26.1.2/libobs/../cmake/external/ObsPluginHelpers.cmake
Call Stack (most recent call first):
CMakeLists.txt:19 (include)
-- Configuring incomplete, errors occurred!
See also "/home/javier/Projects/OBS26/obs-rgb-levels-filter/build/CMakeFiles/CMakeOutput.log".
I am attaching CMakeOutput.log on this post
  • CMakeOutput.log
