Roblox Problem
Slley
I've been using OBS for a while now, but I can't record Roblox via game capture, as it stays on a black screen, but if I try to record via window capture or screen capture, Roblox apparently runs without problems, but right away recording seems to be at 2 fps.
Roblox' recent updates reportedly added an anti-cheat that is blocking game capture from working.
Because of this, any fix to getting game capture working will have to come from either Roblox or their anti-cheat provider.
You will need to use window capture
Slley
"but if I try to record via window capture or screen capture, Roblox apparently runs without problems, but right away recording seems to be at 2 fps."
qhobbes
Slley
Here it is, can you help?
That's an image, not the actual log file.
Follow directions and recommendations you see on the analyzer. After you finish fixing all that, do a new test and post the actual log file, not an image
