Question / Help Seeing frame drops. Recommended settings for my PC?
Zetzaro
I'm curious how I should set up my settings to stream at. I'll attach my pc specs. I'm using a 2560x1440 144hz monitor as the main monitor and the one I stream. I do however keep seeing frame loss for both rendering and encoding lag. Is the issue that my OBS is trying to stream at 2560 or something else? What would the recommended settings be for my OBS with my current specs?
  • DxDiag.txt
  • DxDiag.txt
  • 2019-04-01 20-50-02.txt
