Question / Help Segmentation Fault at start
tekel
Hello, a while ago I had some troubles with OBS only recording my cursor and a black screen whenever any window was selected as Window Capture, ignored it because I have a laptop with OBS running just fine.
However, after the last few Tumbleweed updates my OBS doesn't even start, so I tried to do it via terminal with
$ obs
And I get a segmentation fault, tried removing and reinstalling but that doesn't work either.
Any ideas how to get around this?
My specs:
Videocard: AMD RX460 XFX
OS: OpenSUSE Tumbleweed
Kernel: 4.17.9-1-default
Memory: 8GB RAM
If you need any information to help me out please let me know.
Thanks in advance.
Edit: Attached a file as a proof of the segmentation fault event.
