Bug Report Software Capture not working w/ Spotify and Trillian
imaje
I have tried to search for this extensively so I apologize if I missed the thread.
I successfully added Spotify once as a software capture, but then it turned into a black box. Ever since then I cannot add it or readd it, it continues to show as a black frame or a half transparent frame. Trillian does the same exact thing. They display if i do a monitor capture but not a software capture.
I'm including the log file.
I have rebooted, turned off aero, uninstalled/reinstalled and nothing seems to work.
  • 2013-04-04-0351-43.log
Lain
Lain
I haven't used it, but if it's an application, maybe it's just an opengl app or something and can't capture normally without full monitor capture or window capture with aero disabled. You might want to do a search as well to see if this has happened before to anyone.
