Spout2OverlayHUD
Spout2OverlayHUD 0.2-RC
Marsic1
Marsic1 submitted a new resource:
Spout2OverlayHUD - App that displays Spout2 signal as a HUD overlay on windows, use scenes and sources as overlay
Spout2OverlayHUD​
Spout2OverlayHUD is a Windows application that displays a Spout2 sender signal as a HUD overlay, with direct access to OpenGL textures. Perfect for integrating OBS scenes and sources directly on your screen!
✨ Features​
Low latency: The signal is rendered as an OpenGL texture with minimal performance impact.
Clickthrough window: Does not interfere with user input.
Versatile usage: Ideal...
Marsic1
love this tool but could you make it so that the source is resizable as its super warped on my screen.
on obs you use a different resolution aspect ratio compared too your monitor? i'm thinking of a way to implement it, manual input of the resolution in the tray would work for you?
griffincollins11
This looks like a really useful tool—especially for those of us who work with OBS and want clean overlays without latency issues. I love the clickthrough functionality! Regarding the resizing issue, manual input in the tray sounds like a good start. Maybe down the line, adding a visual drag-to-resize option would make it even more user-friendly. scary games
