Question / Help Starting the output failed (logfile attached)
ThePatriotTV
Happy Holidays everyone,
Unfortunately, I tried switching encoding to all possible settings to no avail.
changed resolutions (1920x1080 etc) to no avail.
Bitrates no avail ; Run as admin during all testing to make sure this can be eliminated.
If I stream on Twitch I can use any feature & settings with success. Trying to Stream on Mixer, specifically for the FTL feature - Faster than Light..
Please see the log file attached. Thank you in advance.
  • 2019-12-27 10-36-20.txt
Narcogen
Problem seems to be selecting audio encoder:
10:37:43.196: [obs-ffmpeg-encoder] Unexpected exception in function '_create': Initializing encoder 'opus' failed with error: Experimental feature (code -733130664).
10:37:43.196: Stream output type 'ftl_output' failed to start!
