Stopping Recording is stuck when I have an active Video Capture Device on my scene
fromguer
Hi all!
I'm having a big problem with OBS and it's driving me crazy.
When I've finished recording, the program gets stuck on "stopping recording" and I have to force-close the "obs-ffmpeg-mux.exe" service to actually stop it. This causes the corruption of the recorded file (if it is a conventional .mp4) or, if I record in .mkv or fragmented .mp4, the appearance of a visible and editable (but of an unpredictable duration) file.
At first I thought it was a generic "stopping recording" issue but I realized that this only happens if I have some Video Capture Device ACTIVE in the scene. If the video capture device is disabled (or it's not there at alll), it would stop and end the recording normally.
I've tried everything: different versions of OBS, updating drivers, trying a thousand and one recording formats and settings and even going back to previous versions of Windows.
The truth is that my cameras (I have several Logitech Brio and one ElGato Camlink 4K) work competently and stably in other programs. The problem must be with how OBS interacts with a Video Capture Devices, and "something" must be happening if I they are present and the record is being stopped.
Any solution you could give me would be greatly appreciated... I use OBS daily for work (I'm a content creator) and I'm as stuck with this as the "stop recording" button :`)
PS: In case it helps, I'm leaving you attached a log file that I just generated, after having to stop the "obs-ffmpeg-mux.exe " process again to get the recording actually stopped. Clean scene, just two Video Capture Devices there, nothing more.
  • 2025-06-16 19-03-55.txt
According to recent previous forum posts, people who reported this were able to fix this issue by uninstalling the Logitune software that comes with some Logitech product.
fromguer
That's interesting... I'm not sure if that would fix the problem... The freeze on "stopping recording" happens even when I'm using other non-Logitech cameras (like the ElGato CamLink 4) on my scene.
The fact that these cameras (and therefore these Logitech drivers) are not involved in the scene and it keeps happening makes me think that maybe that doesn't solve it :(
Furthermore, the Logitune software has been installed for months, and this wasn't happening a week ago...
fromguer
OMG, you were totally right.
I tried to uninstall all the Logitech Software I had, specifically:
  • Logi Tune
  • Logi Capture
  • Logi Options+
And now it works perfectly.
I don't know which specific app was interfering with normal OBS recording, but now I can reinstall them one by one and see if the problem occurs again.
Thank you so much for the suggest @koala !!
Can confirm the "Logi Tune Updater Service" causes the issue. Even closing the Logitune app doesn't fix the problem but as soon as you end the service, the recording stops succsessfully.
Previously I was just ending the task "obs-ffmpeg-mux.exe" which seemed to work fine. It sucks though because I found the Logi Tune app nice and barebones compared to the others Logitech apps.
prgmitchell
If you wouldn't mind it would be helpful to grab a dump of obs-ffmpeg-mux.exe when it is in that "stuck" state and upload it, then message to me directly on here. You can host it anywhere like google drive or dropbox. You can right click it in task manager and create a dump file from that menu.
Pamplu
I made an account here in order to say thank you! I had the same problem and uninstalling the Logi Tune app fixed it indeed.
