Stream Constantly Disconnecting and reconnecting
FancyMonkey34
Ive recently moved to kick and whenever I start a stream it starts for a few seconds before I get the disconnected notification. I haven't been able to resolve the issue. Heres the log file.
  • 2023-08-26 02-01-23.txt
Please revew and follow directions and recommendations on the analyzer:
On the slow network connection, you need to consult help from the brand of your network adapter to make it work correctly at 1Gb, unless your router / modem is not capable of this and then you need to change that.
You can also use https://r-1.ch/R1TCPOptimizer.zip to optimize or fix your network adapted driver. Just make sure you do understand what you're doing.
Harold
Their documentation doesn't actually reflect current limits. Some users are limited as low as 3500
