Question / Help Stream Dc's every 30 minutes, Help, I wanna stream again
CMnickTV
Hey everyone,
So, I am running into a issue that just reared it's head a few days ago and i am not sure what to do
So, if somebody could check out my LOG and get back to me, that would be great
There is quite a few things i wanna play on stream but this issue is keeping me from doing it
Thanks for the help!
  • 2019-06-25 16-50-09.txt
Narcogen
17:29:50.479: WriteN, RTMP send error 10054 (2161 bytes)
17:29:50.479: WriteN, RTMP send error 10053 (80 bytes)
17:29:50.479: WriteN, RTMP send error 10038 (42 bytes)
17:29:50.479: [rtmp stream: 'simple_stream'] Disconnected from rtmp://live-ord.twitch.tv/app
17:29:50.479: Output 'simple_stream': stopping
17:29:50.479: Output 'simple_stream': Total frames output: 118277 (129566 attempted)
17:29:50.479: Output 'simple_stream': Total drawn frames: 129641 (129642 attempted)
17:29:50.479: Output 'simple_stream': Number of lagged frames due to rendering lag/stalls: 1 (0.0%)
17:29:50.479: Output 'simple_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 11289 (8.7%)
Twitch is disconnecting you because they stopped receiving packets from OBS. (Not sure if the 8% of packets dropped is all from the connection dropping, or if your connection is just too slow for your selected bitrate.
Run TwitchTest.
https://r1ch.net/projects/twitchtest
