Question / Help Stream Lags ONLY when running game.
srawat
So I wanted to start streaming league of legends and when I stream without the game running all seems fine. I get the desired set bitrate etc. but as soon as I start the game the stream loses frames and bitrate drops from what I understand the bottom right corner square turns red and bitrate indicated goes from 2500 kbps to 0. The game is running fine while the stream suffers. I tried to run the stream multiple times and for some unknown reason it has worked perfectly once which means to me that it can work again. After searching every nook and cranny of the internet I was concerned whether the game was using up all GPU resources and OBS is on low priority or something like that cause if the GPU was being overloaded then the game should be lagging too but it isn't.
Computer specs:
Processor: i5-9300H CPU @ 2.40 GHz
RAM: 8.00 gb
64-bit OS
Internet is also fine 90 mbps download and upload speed.
I am posting the log files. Please check and let me know what the issue is and how to fix.
  • 2020-04-19 01-10-25.txt
  • 2020-04-19 01-57-10.txt
  • 2020-04-19 02-02-22.txt
  • 2020-04-19 02-06-55.txt
  • 2020-04-19 02-29-50.txt
