Bug Report Streaming 24/7 - Blackscreen randomly.
elfking
Hi All,
Quick background, I am setting up some streaming to be done 24/7 and I am using 'Game Capture'. I have to restart the program about every 30 minutes, so the log file reflects this. However catching the blackscreen problem I can see the specific line in the log when this happens seems to be:
10:23:40: Capture window 0x002A0334 invalid or changing, terminating capture
Warning -- GraphicsCaptureSource::BeginScene: Failed to inject library, error code = -5
10:53:40: Capture window 0x00310378 invalid or changing, terminating capture
Once this problem occurs (bolded) it then will continue to be a black screen even if you stop / start streams until you quit OBS completely and restart it.
Log file: is attached!
I am hoping to solve this as soon as possible and willing to pay a bounty to the correct solution! Unfortunately since it is an issue which doesn't happen all the time may take some time to test that it is 'fixed'
Thank you for the help,
-Brian
  • 2014-04-16-1706-33.log
R1CH
Error 5 means access is denied, ie the process you are trying to capture requires admin permissions or is blocking hooks.
