Question / Help Streaming lag, 2.2mb/s
disengageql
Hi,
I have been having lag problems with my stream, when getting into fights while playing Quake.
my specs are:
AMD 965BE Stock CLock
4GB RAM
7950 AMD
40 mbps Down
2 mbps UP
My ping just sky rockets if I use anything above 1000 kbps. plz help
EDIT* Sorry for not including log.
  • 2013-05-13-2233-59.log
dodgepong
Administrator
Community Helper
Hmm, that log is of you using 1000 or 1350 bit rate, and no dropped frames...can you post a log where you were using a higher bit rate that caused you to drop frames and lag?
disengageql
Well I guess not dropped frames, but definitely lower framerates. Goes from 125 - 100 and feels VERY sluggish, and in a fast game like Quake thats a big deal. Also, my ping will go from 30 - 100 in a firefight. Also no good. I guess I was posting to see if there are better recommended settings I could try...I just dont really want to lose a ton of quality.
