Question / Help Sudden Crashing with Audio Plugins?
TheXyPod
Hey All,
I've run into an issue all of a sudden where OBS just freezes to the point where I need to end it with task manager. I was able to get a crash report out of it last time, but I don't really understand it. I use a plugin called pitch monster to add some effects on stream, and in the report it seems to be the culprit. Thing is, I've been using it for about 3 months now without issue and never updated or touched any settings. I'm hoping someone with a bit more technical flair might be able to identify exactly what's causing the issue. Any help is very much appreciated!
  • Crash 2019-11-22 21-06-42.txt
The log tells that OBS crashed in pitchmonster.dll, which is a vst plugin. That's all, more cannot be said from the log. The exact action isn't available, since there is no debug symbol information for pitchmonster.dll available.
TheXyPod
Thanks for the reply! I wasn't sure if there was any more useful information on the log or not. I guess I'll just stop using the plugin.
