Question / Help To many audio tracks?
Tiny Bole
So I recorded some footage of me and my bud playing a game with my Desktop recording on Track 1 and 2 and I also had my Blue Yeti recording on Track 1 and 3 yet when I open it up in Sony Vegas I have 6 audio tracks with some tracks not even picking up anything. I'm not great with the audio settings in OBS I recently had to get help from this website yesterday. I'll have my settings included. I would like to just have tracks for my Game Audio and obviously my Blue Yeti Audio.
Log File: https://obsproject.com/logs/9A1Nnsa6QCVrCwko
  • OBS 24.0.3 (64-bit, windows) - Profile_ Untitled - Scenes_ Untitled 10_23_2019 11_19_59 PM.png
Zeros.81
Try this
https://www.youtube.com/watch?v=9IW4TDJkw7E
When importing files into Vegas Pro 15 especially ones from Geforce Experience you get a bug that splits the stereo track into two channels. I have just purchased vegas 15 and came across this problem. Hopefully this fix can help you guys out if you are experiencing this problem.
1. Hold down the SHIFT key while opening Options / Preferences
Click the Internal tab.
2. In the field "Show only pref containing:" file type "So4" without the quotes.
3. Set "Enable So4 Compound Reader for AVC/M2TS" to FALSE.
4. Click OK then Restart VP15
If you apply this fix to existing projects it will duplicate your tracks so ensure that you start a new project once you have done the audio fix.
