Bug Report Twitch.tv stream reconnecting switching servers
harriheyl
Hello
I stream from London and there are two twitch servers to choose from. I've found that if I choose the one with the least jitter my stream can run ok for hours, but eventually will disconnect. I then have to switch to the secondary server and the cycle continues. Is this normal? (If I don't switch server it will keep disconnecting) Is changing servers a regular thing? I've tried all sort of different setting, bitrates, etc but this is the only thing I have to change, otherwise OBS works great.
I have attached the log file just in case.
  • 2013-09-15-1150-43.log
Lain
Lain
I don't believe this is a bug, reason why I say is I know people who stream for like 12 hours with no problems, and we recently did tests for disconnection issues for really incredibly long duration streams with little issue as well.
Also, is that a wireless adapter? For the most reliable connection it's always better to use a direct connection (though for all I know that thing has cable inputs)
