Bug Report UE4 - Switching Between Lit modes
DarthNerdist
When running OBS and the UE4 Editor, all is well. I get a good capture and recording.
But if I decide I want to switch between lit and unlit in the editor, suddenly OBS just record a black screen.
The only things that will show up are pop up menus when I hover certain areas of the editor.
Stop and re-starting the recording doesn't fix this. The only way to get OBS to record properly again is to close the editor completely and re-open it.
I'm using Game Capture in OBS, as no other way seems to work for UE4.
EDIT: Same thing happens when I switch to terrain mode to paint and sculpt the terrain....
So basically, I can't do anything but fly through my scene.
And I'm trying to create a demo reel showing my processes of creating a level...
  • log.txt
