Question / Help Video does not capture
BrenBan654
When pressing Preview Stream or Start Recording and your source is a Game Capture, only a few frames are recorded, then the video/stream stops and is stuck on one single frame for the rest of the recording, strangely, you can still record audio, and it will appear. I tried including a log file, but it wouldn't upload.
Boildown
Open the log file, select all, copy and then go to pastebin.com and paste it, link the result here.
Twiixtor
Same problem here. I seem to always have had that problem with OBS Studio. Never had that with Classic. I just got a new drive recently and decided to try OBS again but same problem arises. I even used special video capturing settings found here on the forums but the problem is still here.
EDIT: Same thing happening with Classic now :/
BrenBan654
It has been 3 months and no discussion here, if I can get some answers on what's causing the problem, then that would be nice, also, if the problem affects more sources other than Game Capture, include those too.
Boildown
You need to post a log file to the internet, not link a local file on your hard drive which no one but you can access.
Ked
I had this problem a long time ago, but I fixed it by lowering the quality and frames I had it set to record. Then your video should be less choppy, and won't get stuck on a single frame.
BrenBan654
I didn't get on in a while to see that since I wasn't using OBS from December to January.
This time I have a link to pastebin instead of the link to the local file: http://pastebin.com/QD4YD0Gh
Edit: Also a file if you want to see that, I tried that first, but I thought it didn't upload, because of the loading indicator in the top right.
  • 2016-08-20-1744-33.log
