Video gradually falling behind audio... where can I start investigating?
jbrains
Hi, folks. I've been using OBS Studio for years and I love it, but I've noticed a problem in the last few weeks (maybe 2 months?) and I would like your help in devising next steps for how to investigate.
No, I haven't found anything in a log file to help yet. Either there is no helpful log information or I don't yet know how to recognize it. Certainly, I see nothing obvious so far.
When I use an external/USB web cam with OBS Studio, the video and audio become unsynchronized and the gap between video and audio increases over time. This means that I can't merely apply a fixed audio offset to fix the problem.
Worse, the video falls behind the audio at what seems like intermittently-growing and unpredictable amounts. At the very least, I haven't noticed a pattern.
If I restart OBS Studio, then video and audio become synchronized again... for a while. Sometimes I notice a sizable gap after 15 minutes, sometimes longer. I haven't been able yet to find a correlation between what I'm doing and how this gap grows. Sometimes I go 30-40 minutes and it seems fine.
How much is significant? Sometimes the video is behind my speaking voice by more than 1 full second. In my test today, it fell behind about 0.5 seconds after about 2 hours. (I haven't reached the point of trying to measure more precisely yet.) It certainly becomes noticeable quite often within 20 minutes.
I strongly believe that OBS Studio is involved in the problem, because I did a two-hour-long test with only the V4L2 Test Bench and video did not fall behind audio. This also happens when I use my external/USB webcam, but not when I use my internal webcam. (Or, at least, if it happens with my internal webcam, then the gap grows much much more gradually.) I have also tested this with both a Flatpak version and a native-installed version of OBS Studio, and I observe the behavior in both. I am not yet aware of when this problem began to occur, but I have at least used this external webcam and OBS Studio without observing this problem on Zoom and Google Meet meetings lasting well over an hour.
I'm mostly interested in two things:
- Wild hypotheses worth testing.
- Suggestions on what to try to rule out next and how.
Even so, I'm happy for any help you can offer. Of course, if you recognize this problem and have a strong idea what's going on and how to fix it, I'd love that.
I'm running Pop!_OS 22.04 on Linux kernel 6.12.10 with OBS Studio 31.0.4 Flatpak or OBS Studio 30.2.3 installed from the PPA Repository. My external webcam is an Anker PowerConf C200, which I've been using for well over a year. I'm running a System76 Lemur Pro 10.
What else can I tell you that might help?
Many thanks.
hurikhan77
Do you record audio directly from the ALSA device, or do you record everything from Pipewire? Different audio devices do not have perfectly identical clocks, OBS might not compensate for that. But pipewire should do that.
jbrains
I'm capturing audio using a PulseAudio device and video using a V4L2 device, at least according to the names of the source types in OBS Studio. I can only trust those names; I don't know how to confirm what they're actually doing. I am doing things however I have been doing them for years, meaning since before Linux distributions began adopting PipeWire.
I see new options in OBS Studio 31.0.4 for capturing video through PipeWire, but I don't see the corresponding option for audio. I don't know enough about PipeWire to know how to do that.
To be clear, when I say that video is falling behind audio, I also mean that my video monitor (live echoing of the video signal) in OBS Studio is lagging behind and gradually lagging farther behind over time. (I raise my hand and the video preview in OBS Studio shows me raising my hand 0.5-1.0 second after.) If audio is also falling behind real time--and I suspect it isn't--then it's falling behind much more slowly. It also turns out that, when OBS Studio records both video and audio together, video is behind audio.
So even if we take audio out of the equation, the video camera is _increasingly_ falling behind real time, rather than maintaining a consistent lag that could be worked around with a fixed audio offset.
jbrains
I have confirmed today that if I run my external webcam and Chrome and Zoom in the web browser, then my video does not lag behind even after two hours. This seems to point directly to OBS Studio has being involved in the problem, but, of course, the problem might lie in something that OBS Studio depends on or uses, rather than there being a problem in OBS Studio itself.
I'm very open and would appreciate any recommendation for "unit" testing that I could do here in order to gather more information.
Many thanks.
jbrains
I have confirmed again that in OBS Studio, while recording my external/USB webcam, the video is synchronized when I start recording and then noticeably out of sync (0.25 seconds?) after 25 minutes. I will repeat the same test without recording to see what happens.
jbrains
I have just confirmed that, even when I'm not recording, the video gradually falls behind real time, but more slowly. After about 1 hour, the real-time camera playback shows me noticeably behind real time, maybe more like 0.1-0.2 seconds.
I presume this means something like when the computer is doing more work, OBS Studio falls behind more quickly. Fine.
I'd like to know whether this points to a fixable performance problem in OBS Studio, whether there might be a workaround by configuring my webcam or video capture differently, or something else entirely? I don't know the technology side of video capture enough to make any reasonably intelligent guesses or inferences. I'm hoping one of you will find it in your heart to volunteer to offer some ideas.
Many thanks.
hurikhan77
If you can see pipewire video sources, you're probably already using pipewire for audio even if it says "pulseaudio" - pipewire is compatible to pulseaudio, replacing it as a more modern implementation. Try disabling all audio sources in the global OBS settings that you don't need. Also look in your OBS log if it complains about buffers, and you can use "pw-top" in a terminal to see if the are audio buffer problems.
Maybe try using 44.1kHz audio instead of 48kHz, or vice versa...
If it is a V4L2 video device OBS source, is the "use buffering" property unchecked? When "use buffering" _is_ checked, the video will very likely fall behind at some point.
jbrains
Aha!! Indeed, "Use buffering" is checked. I will experiment with unchecking it and seeing what happens.
What I don't know is whether this was always a ticking time-bomb which only recently exploded _or_ this was a new feature recently and it is checked by default _or_ I happened to check this box absentmindedly, thinking it seemed wise.
I hope this helps! Thank you very much for the idea. It's the kind of thing that seems obvious in retrospect, but wasn't something I would think of in advance.
I'll be back to report my findings.
jbrains
Early returns are very positive! I noticed no lag at all once I unchecked "Use buffering" for my external webcam, even after using the webcam for 90 minutes consecutively with OBS Studio 31.0.4 on Flatpak. I'll keep testing, but I suspect that @stephematician found the source of the problem.
Many thanks!!
jbrains
It's a weird default! This has been raised by developers, but it hasn't gained much traction in terms of ... how/do we fix it: https://github.com/obsproject/obs-studio/discussions/11142
Thank you for this reference! I'm genuinely surprised that my web searching never found this. I understand the problem a bit better now. It seems that I was on the right track with my reasoning (this is some kind of throughput problem), but it didn't occur to me to think of OBS Studio buffering, then gradually falling behind due to consuming "out of date" frames, rather than skipping them and "jumping forward" to real time. And I appreciate that, at the detailed level, this is tricky to implement. I was very likely going to continue down the road of ruling out USB throughput problems and I genuinely don't want an M.Sc. in USB. :P
