Video output is corrupted regardless of output format
Richbai90
Every time I try to capture a video recording using OBS Studio, the output is an mkv file that is 0 seconds long and won't play. There's no audio, or video. Here is the information I can provide
Configuration
  • Linux Distro
    • OS: Debian variant, pop_os
    • Kernel: 5.15.5-76051505-generic
  • Hardware configuration
    • CPU/GPU: AMD Ryzen 7 5700U w/ Radeon Graphics
    • Cores: 16
    • RAM: 32 GB
    • Available Disk Space: > 1TB
    • Displays: 2 (mirrored)
  • Software configuration:
    • OBS Version:27.2.0 (Linux 64 bit)
    • Installation Method: Flatpak
    • User: standard unprivileged (not sudo)
    • Sources:
      • Device: Screen DisplayPort-0 (1280x1024 @ 0,0)
        • Capture Cursor: true
      • Device: Video Capture 4 (usb-0000:05:00.4-4)
        • Input: Camera 2
        • Video Format: Motion-JPEG
        • Resolution: Unchanged
        • Frame Rate: Unchanged
      • Device: Family 17h (Models 10h-1fh) HD Audio Controller Analog Stereo
        • Driver: Pulse Audio
    • Output
      • Mode: Simple
      • Video Bitrate: 2500 kbps
      • Encoder: software (x264)
      • Audio Bitrate: 160
      • Enable Advanced Encoder Settings: False
      • Recording Path: $HOME/Videos
      • Quality: High Quality, Medium Size
      • Format: MKV
      • Custom Muxer Settings: None
      • Enable Replay Buffer: False
    • Audio
      • Sample Rate: 48 kHz
      • channels: stereo
What have I tried
  • Run as sudo - Fails with file not found error
  • Restart computer - No difference
  • Tried Multiple Output formats - No difference
Log file
Attached
  • obs.log
Richbai90
UPDATE:
  • Reinstalled OBS as system package from official apt repo, and installed all required and reccomended dependencies
    • No differece
  • Ran OBS as root
    • Works when installed from apt, still no difference
  • Attempted to record from just a static image source
    • No difference
The issue must be with generating the mkv file somewhere, but I don't know where. I have verified that I have ffmpeg installed, but still the error persists
Richbai90
Wow I feel stupid... Had a thought it might be the default media player. Installed VLC, it works flawlessly.
