Visual Error in Stream
Khasim
Hi...When I stream League of Legends and move the camera in-game, a visual error appears that's quite annoying for me. I've tried lowering the resolution of the live stream, but even if I stream at 480p 30fps, this visual error still appears. I usually have the bit rate between 6000 and 8000.
Video: https://www.twitch.tv/khasim__/clip/EasySmoothBillBudBlast-5QF7EXO_rMr3UarO
(I exaggerated the camera movement on purpose to better illustrate what I'm talking about)
PC: NVIDIA 4060
I7-13620H
16GB RAM
Internet:
500mb Download
12mb Upload
R1CH
Khasim
PC: NVIDIA 4060
I7-13620H
16GB RAM
Internet:
500mb Download
12mb Upload
Log File: https://obsproject.com/logs/c1d87hJ1D4fqrvBa
What you mean with visual error? If it's the pixelation when moving (panning) the camera, that's normal.
R1CH
Yeah your settings look fine, that's about what to expect from 6mbps and high motion.
Khasim
I'm talking about this visual glitch. You see how it distorts and changes color at the same time, as if it were duplicated? This happens when I move the camera in-game (this bug is only visible on the stream).
Khasim
PC: NVIDIA 4060
I7-13620H
16GB RAM
Internet:
500mb Download
12mb Upload
After testing multiple configurations, I found two solutions to the issue I mentioned:
1️⃣ Cap the FPS at 60
OR
2️⃣ Disable G-SYNC in the NVIDIA Control Panel
⚠️ Important: Disabling V-Sync in the game does not fix the problem.
Both options prevent the visual bug that occurs while streaming, but each has its pros and cons:
Option 1: Limit FPS to 60
  • Pros: Provides a stable image while streaming, especially if you play other games with G-Sync enabled.
  • Cons: If your monitor supports a high refresh rate (120/144/240 Hz), you won’t be taking full advantage of it.
Option 2: Disable G-SYNC in the NVIDIA Control Panel
  • Pros: Allows you to fully utilize your monitor’s refresh rate and achieve FPS higher than 60.
  • Cons: With G-Sync disabled, FPS may become unstable, and you might experience occasional micro-stuttering.
