What are the best settings for my PC specs? (obs log included)
Zuuziii
I started streaming with my limited knowledge of obs settings, and I wanted to ask you what the best possible settings are for streaming and recording with my specs :
CPU: Ryzen 5 3600
GPU: GTX 1660 Super 4 GB
RAM: 16GB
testmy.net Upload result is 10 Mbps
My monitor Resolution is 1440 x 900 with a refresh rate of 59,887 Hz
I have a display problem where the stream quality is 720p, but it looks too blurry even though it is only a drawing stream with no sudden movements. (Clip Studio Paint)
You can check one of my blurry streams here: https://www.youtube.com/watch?v=4uGqHoPIlp4
(the line I drew is chalky, blurry, and Pixelated it affects the text as well)
I researched some YouTube videos about streaming but my stream is still blurry with those settings. (This does not rule out the possibility of gaming streaming in the future )
all I can show you is my obs log here: https://pastebin.com/2pKCdX7h
I hope I can use my specs with the fullest power possible.
  • 2024-12-14 22-11-06.txt
