Question / Help What are the best settings for OBS for my PC?
Luke Nutman
Hello everyone I have recently started wanting to set up a YouTube Channel for recording and a Twitch Channel for streaming. I would really like it if someone can help me and give the best settings I can have for my recording. I am really wanting to aim for at least 720p but if I can 1080p would be great. However, 480p I am happily to do if anyone can tell me what I need to get a 720p recording/stream.
Here are the specs for my PC:
Processor:
AMD A10-6800K APU with Radeon(tm) HD Graphics 4.10GHz - Quad Core
Video Card:
AMD Radeon R9 200 Series - R9 270X 4G D5
RAM:
8GB
OS:
Windows 10 Pro 64-bit
Maximum Resolution:
1920 x 1080
Hard Drive:
Size:
930GB
Available:
170GB (I am going to get another 1TB drive soon)
Internet Speeds:
Ping:
14ms
Download Speed:
57.98Mbps
Upload Speed:
16.22Mbps
Hope someone can help me.
Thanks!
Luke Nutman
I have tried this and it works ok however now I get a problem where the bottom of the screen is cut off when i am in the game. I have made the resolution slightly bigger and fixed the problem. But this now causes the image to go weird at random points during the video. I set the resolution to 1920x1100 i know this is not a normal resolution but it is what I had to do to stop the screen from getting cut off.
alpinlol
delete the capture then and readd it also make sure that you chose your monitor in settings and not set custom resolution
Luke Nutman
I have tried to set it so that its not a custom resolution but it changes back when I open up the setting again and yes I did click apply.
