When trying to recording on Macbook Pro M3, I get an error. Changing my encoder doesn't fix
skngh
It tells me
"Starting the output failed. Please check the log for details."
Here's the log:
13:36:05.379: CPU Name: Apple M3 Pro
13:36:05.379: CPU Speed: 2400MHz
13:36:05.379: Physical Cores: 12, Logical Cores: 12
13:36:05.379: Physical Memory: 18432MB Total
13:36:05.379: OS Name: Mac OS X
13:36:05.380: OS Version: Version 14.1 (Build 23B2073)
13:36:05.380: Kernel Version: 23.1.0
13:36:05.393: hotkeys-cocoa: Using layout 'com.apple.keylayout.ABC'
13:36:05.393: Current Date/Time: 2024-02-29, 13:36:05
13:36:05.393: Browser Hardware Acceleration: true
13:36:05.393: Portable mode: false
13:36:05.458: OBS 27.0.0 (mac)
13:36:05.458: ---------------------------------
13:36:05.458: audio settings reset:
13:36:05.458: samples per sec: 44100
13:36:05.458: speakers: 2
13:36:05.460: ---------------------------------
13:36:05.460: Initializing OpenGL...
13:36:05.492: Loading up OpenGL on adapter Apple Apple M3 Pro
13:36:05.492: OpenGL loaded successfully, version 4.1 Metal - 88, shading language 4.10
13:36:05.550: ---------------------------------
13:36:05.550: video settings reset:
13:36:05.550: base resolution: 3024x1964
13:36:05.550: output resolution: 3024x1964
13:36:05.550: downscale filter: Bicubic
13:36:05.550: fps: 30/1
13:36:05.550: format: NV12
13:36:05.550: YUV mode: 709/Partial
13:36:05.550: NV12 texture support not available
13:36:05.551: Audio monitoring device:
13:36:05.551: name: Default
13:36:05.551: id: default
13:36:05.551: ---------------------------------
13:36:05.553: Failed to load 'en-US' text for module: 'decklink-captions.so'
13:36:05.554: Failed to load 'en-US' text for module: 'decklink-ouput-ui.so'
13:36:05.560: os_dlopen(libpython3.9.dylib->libpython3.9.dylib): dlopen(libpython3.9.dylib, 0x0101): tried: 'libpython3.9.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OSlibpython3.9.dylib' (no such file), '/Applications/OBS.app/Contents/Frameworks/libpython3.9.dylib' (no such file), '/Applications/OBS.app/Contents/Frameworks/libpython3.9.dylib' (no such file), '/Applications/OBS.app/Contents/Frameworks/libpython3.9.dylib' (no such file), '/Applications/OBS.app/Contents/Frameworks/libpython3.9.dylib' (no such file), '/usr/lib/libpython3.9.dylib' (no such file, not in dyld cache), 'libpython3.9.dylib' (no such file), '/usr/lib/libpython3.9.dylib' (no such file, not in dyld cache)
13:36:05.560:
13:36:05.560: [Python] Could not load library: libpython3.9.dylib
13:36:05.626: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
13:36:05.626: No blackmagic support
13:36:05.628: [mac-virtualcam] version=1.3.0
13:36:05.680: [VideoToolbox encoder]: Adding VideoToolbox H264 encoders
13:36:05.683: [obs-browser]: Version 2.14.3
13:36:05.683: [obs-browser]: CEF Version 85.0.0-HEAD.2273+g93b66a0+chromium-85.0.4183.121
13:36:05.714: os_dlopen(/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib->/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib): dlopen(/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib, 0x0101): tried: '/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib' (no such file), '/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib' (no such file)
13:36:05.714:
13:36:05.714: Couldn't find VLC installation, VLC video source disabled
13:36:05.717: Loading iOS Camera Plugin (version 2.8.0)
13:36:05.717: ---------------------------------
13:36:05.717: Loaded Modules:
13:36:05.717: obs-ios-camera-source.so
13:36:05.717: vlc-video.so
13:36:05.717: text-freetype2.so
13:36:05.717: rtmp-services.so
13:36:05.717: obs-x264.so
13:36:05.717: obs-vst.so
13:36:05.717: obs-transitions.so
13:36:05.717: obs-outputs.so
13:36:05.717: obs-filters.so
13:36:05.717: obs-ffmpeg.so
13:36:05.717: obs-browser.so
13:36:05.717: mac-vth264.so
13:36:05.717: mac-virtualcam.so
13:36:05.717: mac-syphon.so
13:36:05.717: mac-decklink.so
13:36:05.717: mac-capture.so
13:36:05.717: mac-avcapture.so
13:36:05.717: image-source.so
13:36:05.717: frontend-tools.so
13:36:05.717: decklink-ouput-ui.so
13:36:05.717: decklink-captions.so
13:36:05.717: coreaudio-encoder.so
13:36:05.717: ==== Startup complete ===============================================
13:36:05.717: Encoder ID 'com.apple.videotoolbox.videoencoder.h264.gva' not found
13:36:05.730: All scene data cleared
13:36:05.730: ------------------------------------------------
13:36:05.939: coreaudio: device 'MacBook Pro Microphone' initialized
13:36:05.939: [Loaded global audio device]: 'Mic/Aux'
13:36:05.949: coreaudio: device 'MacBook Pro Microphone' initialized
13:36:05.949: [Loaded global audio device]: 'Mic/Aux 2'
13:36:05.982: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds (source: Mic/Aux 2)
13:36:05.982:
13:36:05.982: Video Capture Device: Selected device 'FaceTime HD Camera'
13:36:05.983: Video Capture Device: Using preset 1280x720
13:36:06.753: Switched to scene 'Screen/face'
13:36:06.753: ------------------------------------------------
13:36:06.753: Loaded scenes:
13:36:06.753: - scene 'Screen/face':
13:36:06.753: - source: 'Display Capture' (display_capture)
13:36:06.753: - source: 'Video Capture Device' (av_capture_input)
bankableprofits
I'm getting the same. I'm on MacBook Air M3
Attached are my logs. The txt was too much to paste.
Thanks in advance.
  • 0BS logs 2024-04-05 10-41-35.txt
