Question / Help Why does OBS crash my Minecraft!
Jamie Spiteri
Hi I have been using OBS for a while now with no issues and just recently got my new laptop so I have set everything back up on my laptop including OBS. It was working perfectly for the last week, recording my monitor, Minecraft and CS:GO (Counter Strike Global Offensive).
This morning I launched Minecraft and OBS ready to record and after I was ready I hit my start recording hotkey (F9) and then my Minecraft crashed and popped up with a crash report (Image Linked)
I've tried tweaking settings but couldn't get anything to work. It only crashes in Game Capture mode but I don't like to record in any other mode because it doesn't look good!
I've tried un-installing & re-installing Minecraft & OBS and also Java, but OBS still crashes Minecraft.
This is very annoying and I'm unsure why this is happenening, if anyone knows how to fix this please, please, please can you help me cause I really want to continue to use OBS for Minecraft cause it is what I am used to using and I'm dying on the inside!! :D
Logs (These are just the logs from re-installation and setting back up):
[ 08:43:14: Open Broadcaster Software v0.657b - 32bit (´・ω・`)
08:43:14: -------------------------------
08:43:14: CPU Name: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
08:43:14: CPU Speed: 2592MHz
08:43:14: Physical Memory: 4095MB Total, 4095MB Free
08:43:14: stepping id: 3, model 94, family 6, type 0, extmodel 2, extfamily 0, HTT 1, logical cores 8, total cores 4
08:43:14: monitor 1: pos={0, 0}, size={1920, 1080}
08:43:14: Windows Version: 10.0 Build 10586 (revision 0)
08:43:14: Aero is Enabled
08:43:14: OBS Modules:
08:43:14: Base Address Module
08:43:14: 00BA0000 OBS.exe
08:43:14: 53B80000 OBSApi.dll
08:43:14: 53910000 DShowPlugin.dll
08:43:14: 538E0000 GraphicsCapture.dll
08:43:14: 538B0000 NoiseGate.dll
08:43:14: 53890000 PSVPlugin.dll
08:43:14: 53870000 scenesw.dll
08:43:14: ------------------------------------------
08:43:14: Adapter 1
08:43:14: Video Adapter: NVIDIA GeForce GTX 960M
08:43:14: Video Adapter Dedicated Video Memory: 3221225472
08:43:14: Video Adapter Shared System Memory: 1073676288
08:43:14: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
08:43:14: Adapter 2
08:43:14: Video Adapter: Intel(R) HD Graphics 530
08:43:14: Video Adapter Dedicated Video Memory: 134217728
08:43:14: Video Adapter Shared System Memory: 4160684032
08:43:14: =====Stream Start: 2016-07-06, 08:43:14===============================================
08:43:14: Multithreaded optimizations: On
08:43:14: Base resolution: 1920x1080
08:43:14: Output resolution: 1920x1080
08:43:14: Loading up D3D10 on NVIDIA GeForce GTX 960M (Adapter 1)...
08:43:14: Audio Format: 48000 Hz
08:43:14: Audio Channels: 2 Ch
08:43:14: Playback device Default
08:43:14: Using desktop audio input: Speakers (Realtek High Definition Audio)
08:43:14: Global Audio time adjust: 0
08:43:14: Audio Encoding: AAC
08:43:14: bitrate: 128
08:43:14: Using graphics capture
08:43:14: Trying to hook process: javaw.exe
08:43:14: Scene buffering time set to 700
08:43:14: Video Encoding: x264
08:43:14: fps: 60
08:43:14: width: 1920, height: 1080
08:43:14: preset: veryfast
08:43:14: profile: high
08:43:14: keyint: 250
08:43:14: CBR: yes
08:43:14: CFR: yes
08:43:14: max bitrate: 1000
08:43:14: buffer size: 1000
08:43:16: FlushBufferedVideo: Flushing 21 packets over 333 ms
08:43:17: Total frames encoded: 81, total frames duplicated: 0 (0.00%)
08:43:17: Total frames rendered: 109, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
08:43:17:
08:43:17: Profiler time results:
08:43:17:
08:43:17: ==============================================================
08:43:17: video thread frame - [100%] [avg time: 0.824 ms] [children: 19.5%] [unaccounted: 80.5%]
08:43:17: | scene->Preprocess - [0.243%] [avg time: 0.002 ms]
08:43:17: | GPU download and conversion - [19.3%] [avg time: 0.159 ms] [children: 18.8%] [unaccounted: 0.485%]
08:43:17: | | flush - [17.2%] [avg time: 0.142 ms]
08:43:17: | | CopyResource - [0.971%] [avg time: 0.008 ms]
08:43:17: | | conversion to 4:2:0 - [0.607%] [avg time: 0.005 ms]
08:43:17: Convert444Threads - [100%] [avg time: 1.404 ms] [children: 99.3%] [unaccounted: 0.712%]
08:43:17: | Convert444toNV12 - [99.3%] [avg time: 1.394 ms]
08:43:17: encoder thread frame - [100%] [avg time: 3.058 ms] [children: 0.164%] [unaccounted: 99.8%]
08:43:17: | sending stuff out - [0.164%] [avg time: 0.005 ms]
08:43:17:
08:43:17:
08:43:17: Profiler CPU results:
08:43:17:
08:43:17: video thread frame - [cpu time: avg 0.43 ms, total 46.875 ms] [avg calls per frame: 1]
08:43:17: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
08:43:17: | GPU download and conversion - [cpu time: avg 0.143 ms, total 15.625 ms] [avg calls per frame: 1]
08:43:17: | | flush - [cpu time: avg 0.143 ms, total 15.625 ms] [avg calls per frame: 1]
08:43:17: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
08:43:17: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
08:43:17: Convert444Threads - [cpu time: avg 1.536 ms, total 187.5 ms] [avg calls per frame: 2]
08:43:17: | Convert444toNV12 - [cpu time: avg 1.536 ms, total 187.5 ms] [avg calls per frame: 2]
08:43:17: encoder thread frame - [cpu time: avg 2.864 ms, total 171.875 ms] [avg calls per frame: 1]
08:43:17: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
08:43:17:
08:43:17: =====Stream End: 2016-07-06, 08:43:17=================================================
08:43:21: Terminating 0x2968
Last game capture log:
2016-07-06, 08:43:14: we're booting up:
08:43:14: CaptureThread: attached to process javaw.exe
08:43:14: GL Present
08:43:14: DirectDraw capture: Windows 8 not supported yet
08:43:14: (half life scientist) everything.. seems to be in order
08:43:14: SwapBuffers(3909161366) Called
08:43:14: NV Capture available
08:43:14: FBO available
08:43:14: setting up gl data]
Any help is greatly appreciated,
Thank You
- Spiddy
