Leolph
Hi there,
I'm getting frequent random disconnects and I don't know why.
Having used OBS classic for over 2 years this problem never appeared, although digging here in the forums there were also some guys having this error, but no solution was found.
Since several months I am using OBS Studio and - (just as a sidenote - it's awesome!) and in the last weeks those errors occur.
Here is my log for today's stream:
First I streamed some World of Warcraft, later some Hearthstone. Both games had those issues.
When you look at the log there are dropped frames while rendering in a range from 0,x - 29,x %. So my guess is that I need to optimize my settings. Not sure, but I have the feeling when when CPU load is at 50% just with streaming something might be wrong and causing those problems.
I tried Stream Settings Estimator and got this result:
I'm running 3 monitors with 1920x1200 each, it's the recommend resolution for them, other create black borders.
Videobitrate is set to 2500
Coder x264
Audio 160
Base resolution: 1920x1200
Output resolution: 1920x1200
Scale factor: Bicubic
FPS: 30
Renderer Direct3d 11
CPU priority: normal
Don't know what CFR and CBR is, haven't found it in the settings. What and where are they? :)
Any help is appreciated, thank you in advance,
best regards
Leolph
http://www.leolph.com/OBS/obslog.txt
Coder x264
Audio 160
FPS: 30
best regards
Leolph
