0.54.09 network test build
Status
Not open for further replies.
tokala
Re: 0.54.08 network test build
With .08 my OBS keeps crashing when i change the scenes while im ingame (Dark Souls).. Heres the log but i dont know if there is anything helpfull in it.. Oh and i change my scenes with hotkeys :x ALT + 1 , ALT + 2 etc.
20:18:59: Open Broadcaster Software v0.54.08 network/gc test - 64bit ( ^ω^)
20:18:59: -------------------------------
20:18:59: CPU Name: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
20:18:59: CPU Speed: 3400MHz
20:18:59: Physical Memory:  8159MB Total, 6229MB Free
20:18:59: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
20:18:59: monitor 1: pos={0, 0}, size={1920, 1080}
20:18:59: Windows Version: 6.1 Build 7601 S
20:18:59: Aero is Enabled
20:18:59: OBS Modules:
20:18:59: Base Address     Module
20:18:59: 000000003FBF0000 OBS.exe
20:18:59: 00000000EBEC0000 OBSApi.dll
20:18:59: 00000000F53E0000 DShowPlugin.dll
20:18:59: 00000000F53B0000 GraphicsCapture.dll
20:18:59: 00000000F52F0000 NoiseGate.dll
20:18:59: 00000000F52B0000 PSVPlugin.dll
20:18:59: ------------------------------------------
20:18:59: Adapter 1
20:18:59:   Video Adapter: NVIDIA GeForce GTX 680
20:18:59:   Video Adapter Dedicated Video Memory: 2091581440
20:18:59:   Video Adapter Shared System Memory: 2147807232
20:18:59: =====Stream Start: 2013-08-07, 20:18:59===============================================
20:18:59:   Multithreaded optimizations: On
20:18:59:   Base resolution: 1920x1080
20:18:59:   Output resolution: 1280x720
20:18:59: Loading up D3D10 on NVIDIA GeForce GTX 680...
20:18:59: Playback device Default
20:18:59: Using desktop audio input: Lautsprecher (Logitech G35 Headset)
20:18:59: Using 7.1 surround speaker setup
20:18:59: Using auxilary audio input: Mikrofon (Logitech G35 Headset)
20:18:59: Audio Encoding: AAC
20:18:59:     bitrate: 128
20:18:59: Using Monitor Capture
20:18:59: Using text output
20:18:59: Using bitmap image
20:18:59: Video Encoding: x264
20:18:59:     fps: 30
20:18:59:     width: 1280, height: 720
20:18:59:     preset: veryfast
20:18:59:     CBR: no
20:18:59:     CFR: no
20:18:59:     max bitrate: 3000
20:18:59:     buffer size: 3000
20:18:59:     quality: 10
20:18:59: MMDeviceAudioSource: Frequency for device 'Lautsprecher (Logitech G35 Headset)' is 1411200, samples per sec is 44100
20:18:59: MMDeviceAudioSource: Frequency for device 'Mikrofon (Logitech G35 Headset)' is 176400, samples per sec is 44100
20:18:59:
20:18:59: Profiler result for the last frame:
20:18:59: ==============================================================
20:18:59: frame - [time: 53.529 ms (cpu time: 15.6 ms)]
20:18:59: | frame preprocessing and rendering - [time: 49.175 ms (cpu time: 15.6 ms)]
20:18:59: | | scene->Preprocess - [time: 47.573 ms (cpu time: 15.6 ms)]
20:18:59: | video encoding and uploading - [time: 4.35 ms (cpu time: 0 ms)]
20:18:59: | | flush - [time: 4.347 ms (cpu time: 0 ms)]
20:18:59:
20:19:01: Using RTMP service: Twitch / Justin.tv
20:19:01:   Server selection: rtmp://live-fra.justin.tv/app
20:19:01:   Interface: Intel(R) 82579V Gigabit Network Connection (ethernet, 1000 mbps)
20:19:04: SO_SNDBUF was at 8192
20:19:04: SO_SNDBUF is now 65536
20:19:14: RTMPPublisher::Socketloop: Increasing send buffer to ISB 131072 (buffer: 0 / 400384)
20:22:09: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
20:22:09:   New Scene
20:22:09: Using graphics capture
20:22:10: SharedTexCapture hooked
20:22:46: RTMPPublisher::Socketloop: Increasing send buffer to ISB 262144 (buffer: 0 / 400384)
21:05:51: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
21:05:51:   New Scene
21:05:51: Using Monitor Capture
21:05:51: Using text output
21:05:51: Using bitmap image
21:07:44: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
21:07:44:   New Scene
21:07:44: Using graphics capture
21:07:45: SharedTexCapture hooked
21:08:16: RTMPPublisher::SocketLoop: Aborting due to FD_CLOSE, error 0
21:08:17: Total frames rendered: 88711, number of late frames: 15 (0.02%) (it's okay for some frames to be late)
21:08:17: Number of times waited to send: 0, Waited for a total of 0 bytes
21:08:17: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
21:08:17: =====Stream End: 2013-08-07, 21:08:17=================================================
21:08:27: =====Stream Start: 2013-08-07, 21:08:27===============================================
21:08:27:   Multithreaded optimizations: On
21:08:27:   Base resolution: 1920x1080
21:08:27:   Output resolution: 1280x720
21:08:27: ------------------------------------------
21:08:27: Loading up D3D10 on NVIDIA GeForce GTX 680...
21:08:27: Playback device Default
21:08:27: Using desktop audio input: Lautsprecher (Logitech G35 Headset)
21:08:27: Using 7.1 surround speaker setup
21:08:27: Using auxilary audio input: Mikrofon (Logitech G35 Headset)
21:08:27: Audio Encoding: AAC
21:08:27:     bitrate: 128
21:08:27: Using graphics capture
21:08:28: ------------------------------------------
21:08:28: Video Encoding: x264
21:08:28:     fps: 30
21:08:28:     width: 1280, height: 720
21:08:28:     preset: veryfast
21:08:28:     CBR: no
21:08:28:     CFR: no
21:08:28:     max bitrate: 3000
21:08:28:     buffer size: 3000
21:08:28:     quality: 10
21:08:28: MMDeviceAudioSource: Frequency for device 'Lautsprecher (Logitech G35 Headset)' is 1411200, samples per sec is 44100
21:08:28: MMDeviceAudioSource: Frequency for device 'Mikrofon (Logitech G35 Headset)' is 176400, samples per sec is 44100
21:08:29: Using RTMP service: Twitch / Justin.tv
21:08:29:   Server selection: rtmp://live-fra.justin.tv/app
21:08:29:   Interface: Intel(R) 82579V Gigabit Network Connection (ethernet, 1000 mbps)
21:08:33: SO_SNDBUF was at 8192
21:08:33: SO_SNDBUF is now 65536
21:08:38: SharedTexCapture hooked
21:08:53: GraphicsCaptureSource::NewCapture:  eliminating old capture
21:08:53: SharedTexCapture hooked
21:09:09: RTMPPublisher::SocketLoop: Aborting due to FD_CLOSE, error 0
21:09:10: Total frames rendered: 1269, number of late frames: 3 (0.24%) (it's okay for some frames to be late)
dodgepong
Administrator
Community Helper
Is it an actual crash, or does it just stop streaming?
Entroper
Re: 0.54.07 network test build
Jim said:
Okay, updated to 07, could you guys see if game capture is still having those issues? iRacing users as well as those of you experiencing the strange CPU usage problem?
I didn't get 07 in time, but 08 seems to have fixed my iRacing crash. :)
tokala
Its an actual crash, my stream went offline before i know it so i tabbed out the game, checked obs and it just crashed : /
tokala
Hmm i only got this log file i posted, if the crash log is somewhere else located like in the main folder then i dont got it anymore couse i deleted it D:
Gol D. Ace
Just found an minor bug.
If you update the name of a profile the updated name doesn't show in the title bar until you switch the profile to another one and back to the renamed one.
EDIT: Also happens when you create a new profile.
Defiasen
This crash appears to have occured in the 'c:\windows\system32\kernelbase.dll' module.
**** UNHANDLED EXCEPTION: 80000003
Fault address: 000007FEFDA23C72 (c:\windows\system32\kernelbase.dll)
OBS version: Open Broadcaster Software v0.54.08 network/gc test
Windows version: 6.1 (Build 7601) Service Pack 1
CPU: AMD Phenom(tm) II X4 965 Processor
Crashing thread stack trace:
Stack            EIP              Arg0             Arg1             Arg2             Arg3             Address
000000000015ECB8 000007FEFDA23C72 000007FEF6015860 000000000000EA60 000000000015EC18 0000000000000003 kernelbase.dll!0x7fefda23c72
000000000015ECC0 000007FEF5E8D053 0000000000283600 0000000000283600 0000000000000003 0000000000000000 obsapi.dll!OSTerminateThread+0x33
000000000015ECF0 000000013F682BE5 0000000002090600 0000000000000000 0000000000000000 0000000000000001 obs.exe!RTMPPublisher::~RTMPPublisher+0xb5
000000000015F170 000000013F682894 0000000000000005 0000000000180190 00000000007100CE 0000000000221A90 obs.exe!RTMPPublisher::`vector deleting destructor'+0x14
000000000015F1A0 000000013F67CFF2 0000000000000002 0000000000000003 000000013F67F0C0 000000013F67A234 obs.exe!OBS::Stop+0x112
000000000015F220 000000013F67F108 0000000000000002 00000000000000C8 4058FF2100800000 0000000000800000 obs.exe!OBS::StopStreamHotkey+0x48
000000000015F250 000000013F652DD7 0000000000000001 000000000015F3A0 0000000000000402 000000000000007E obs.exe!OBS::CallHotkey+0x97
000000000015F2A0 000000013F69C82A 000000000000FF00 0000000000030000 0000000000000402 00000000777C9B43 obs.exe!OBS::OBSProc+0x193a
000000000015F430 00000000777C9BD1 000000000015F6F0 000000013F69AEF0 00000000008B1E60 00000000008B1E60 user32.dll!0x777c9bd1
000000000015F4F0 00000000777C98DA 0000000000000000 0000000000000000 000000013F69AEF0 0000000000000001 user32.dll!0x777c98da
000000000015F570 00000000777C67C2 000000005EF31703 000000005EF31703 000007FEFDDE2164 000000000031FCF0 user32.dll!0x777c67c2
000000000015F600 000000013F6714F9 0000000000000000 0000000000000000 000000013F650000 0000000000000000 obs.exe!WinMain+0x8b9
000000000015FB30 000000013F6E4D50 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!strstr+0x1ac
000000000015FBE0 00000000776A652D 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x776a652d
000000000015FC10 00000000778DC521 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x778dc521
A minidump was saved to C:\Users\New\AppData\Roaming\OBS\crashDumps\OBSCrashDump2013-08-09_1.dmp.
List of loaded modules:
Base Address                      Module
Lain
Lain
tokala - Does it not create an actual crash log?
tokala
Hmm, nope, not for me.. ive looked into the crashdumps folder and into the log folder but there is no crash log.. It just crashed and winodows sayed "obs stopped working"
Lain
Lain
Then you may have to somehow get me a dump from task manager when it's frozen if possible (compressed). It's the only way I can debug it.
Uploaded 09, mostly just a few more minor tweaks and fixes, although most importantly there was a fix for a mic sync issue some people had on rarer occasions. I would like to know if anyone notices anything out of the ordinary with their mics or not with this new code.
Otherwise I'm probably just going to make a full release after this.
Kharay
And Minecraft's crashing again in 0.54.09. Haven't seen this one in a few versions but, the issue is back now. :'(
.09: Minecraft in 1600x900 window -> Windows Capture -> (pick Minecraft) -> Set Base Resolution -> Cancel Window Capture -> Game Capture -> (pick Minecraft) -> start stream -> move Minecraft window -> Java crashes.
.08 will let you move the window without Java crashing.
Arsb3llicA
Just tried testing out the Quick Sync feature in the latest test build (0.54.09). I know I have Quick Sync setup properly because I use it with Mirillis Action when recording gameplay.
Source type: Game Capture
Game: BF3
When I first click on preview stream with BF3 alt tabbed everything seems to be working fine but when I click on the BF3 window which makes BF3 full screen OBS freezes and I have to force close it. OBS works properly with Quick Sync disabled.
I'm running on Windows 8 x64 with 2 Nvidia 460's in SLI and a 2500k.
Not sure if it's fixed in the 09 build but i got this after a time of streaming ... last time it was also after a couple of hours.
19:59:06: Open Broadcaster Software v0.54.08 network/gc test - 64bit ( ^ω^)
19:59:06: -------------------------------
19:59:06: CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
19:59:06: CPU Speed: 3332MHz
19:59:06: Physical Memory:  8159MB Total, 4411MB Free
19:59:06: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
19:59:06: monitor 1: pos={0, 0}, size={1920, 1080}
19:59:06: monitor 2: pos={-1280, 33}, size={1280, 1024}
19:59:06: Windows Version: 6.1 Build 7601 S
19:59:06: Aero is Enabled
19:59:06: OBS Modules:
19:59:06: Base Address     Module
19:59:06: 000000003F860000 OBS.exe
19:59:06: 00000000E7E70000 OBSApi.dll
19:59:06: 00000000EC650000 DShowPlugin.dll
19:59:06: 00000000EAAF0000 GraphicsCapture.dll
19:59:06: 00000000EC720000 NoiseGate.dll
19:59:06: 00000000EC630000 PSVPlugin.dll
19:59:06: 00000000EC280000 scenesw.dll
19:59:06: 00000000EAA00000 WebSocketAPIPlugin.dll
19:59:06: ------------------------------------------
19:59:06: Adapter 1
19:59:06:   Video Adapter: NVIDIA GeForce GTX 560 Ti
19:59:06:   Video Adapter Dedicated Video Memory: 1025966080
19:59:06:   Video Adapter Shared System Memory: 3220779008
19:59:06: =====Stream Start: 2013-08-12, 19:59:06===============================================
19:59:06:   Multithreaded optimizations: On
19:59:06:   Base resolution: 1600x900
19:59:06:   Output resolution: 1280x720
19:59:06: Loading up D3D10 on NVIDIA GeForce GTX 560 Ti...
19:59:06: Playback device {0.0.0.00000000}.{ec118582-431d-43b3-93a7-50cf9c8a9acb}
19:59:06: Using desktop audio input: Luidsprekers (Realtek High Definition Audio)
19:59:06: Using 5.1 speaker setup
19:59:06: Using auxilary audio input: Microfoon (Pro 9000)
19:59:06: Audio Encoding: AAC
19:59:06:     bitrate: 128
19:59:06: Using text output
19:59:06:     device: Logitech QuickCam Pro 9000,
19:59:06:     device id \\?\usb#vid_046d&pid_0990&mi_00#7&322d27b4&2&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
19:59:06:     chosen type: I420, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-2000000, fourCC: 'I420'
19:59:06:     audio device: Disable,
19:59:06:     audio device id Disabled,
19:59:06:
19:59:06: Using directshow input
19:59:06: Using graphics capture
19:59:06: Video Encoding: x264
19:59:06:     fps: 48
19:59:06:     width: 1280, height: 720
19:59:06:     preset: veryfast
19:59:06:     CBR: yes
19:59:06:     CFR: no
19:59:06:     max bitrate: 3500
19:59:06: MMDeviceAudioSource: Frequency for device 'Luidsprekers (Realtek High Definition Audio)' is 4608000, samples per sec is 192000
19:59:06: MMDeviceAudioSource: Frequency for device 'Microfoon (Pro 9000)' is 64000, samples per sec is 16000
19:59:06: SharedTexCapture hooked
19:59:08: Using RTMP service: Twitch / Justin.tv
19:59:08:   Server selection: rtmp://live-ams.justin.tv/app
19:59:08:   Interface: Intel(R) 82579V Gigabit Network Connection (ethernet, 1000 mbps)
19:59:09: SO_SNDBUF was at 8192
19:59:09: SO_SNDBUF is now 65536
19:59:11: RTMPPublisher::Socketloop: Increasing send buffer to ISB 131072 (buffer: 0 / 463872)
19:59:16: RTMPPublisher::Socketloop: Increasing send buffer to ISB 262144 (buffer: 15 / 463872)
21:19:23: Total frames rendered: 231018, number of late frames: 501 (0.22%) (it's okay for some frames to be late)
21:19:24: RTMPPublisher::SocketLoop: Graceful loop exit
21:19:24: Number of times waited to send: 0, Waited for a total of 0 bytes
21:19:24: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
21:19:24: =====Stream End: 2013-08-12, 21:19:24=================================================
21:19:27: =====Stream Start: 2013-08-12, 21:19:27===============================================
21:19:27:   Multithreaded optimizations: On
21:19:27:   Base resolution: 1600x900
21:19:27:   Output resolution: 1280x720
21:19:27: ------------------------------------------
21:19:27: Loading up D3D10 on NVIDIA GeForce GTX 560 Ti...
21:19:28: Playback device {0.0.0.00000000}.{ec118582-431d-43b3-93a7-50cf9c8a9acb}
21:19:28: ------------------------------------------
21:19:28: Using desktop audio input: Luidsprekers (Realtek High Definition Audio)
21:19:28: Using 5.1 speaker setup
21:19:28: Using auxilary audio input: Microfoon (Pro 9000)
21:19:28: Audio Encoding: AAC
21:19:28:     bitrate: 128
21:19:28: Using text output
21:19:28:     device: Logitech QuickCam Pro 9000,
21:19:28:     device id \\?\usb#vid_046d&pid_0990&mi_00#7&322d27b4&2&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
21:19:28:     chosen type: I420, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-2000000, fourCC: 'I420'
21:19:28:     audio device: Disable,
21:19:28:     audio device id Disabled,
21:19:28:
21:19:28: Using directshow input
21:19:28: Using graphics capture
21:19:28: Video Encoding: x264
21:19:28:     fps: 48
21:19:28:     width: 1280, height: 720
21:19:28:     preset: veryfast
21:19:28:     CBR: yes
21:19:28:     CFR: no
21:19:28:     max bitrate: 3000
21:19:28: MMDeviceAudioSource: Frequency for device 'Luidsprekers (Realtek High Definition Audio)' is 4608000, samples per sec is 192000
21:19:28: MMDeviceAudioSource: Frequency for device 'Microfoon (Pro 9000)' is 64000, samples per sec is 16000
21:19:28: SharedTexCapture hooked
21:19:29: Using RTMP service: Twitch / Justin.tv
21:19:29:   Server selection: rtmp://live-ams.justin.tv/app
21:19:29:   Interface: Intel(R) 82579V Gigabit Network Connection (ethernet, 1000 mbps)
21:19:31: SO_SNDBUF was at 8192
21:19:31: SO_SNDBUF is now 65536
21:19:34: RTMPPublisher::Socketloop: Increasing send buffer to ISB 131072 (buffer: 0 / 400384)
21:22:27: RTMPPublisher::Socketloop: Increasing send buffer to ISB 262144 (buffer: 0 / 400384)
22:16:43: Using text output
23:23:52: RTMPPublisher::SocketLoop: Aborting due to FD_CLOSE, error 0
23:23:53: Total frames rendered: 358240, number of late frames: 134 (0.04%) (it's okay for some frames to be late)
23:24:54: WARNING: Forcibly terminating a thread after 60000 ms timeout!
Fault address: 000007FEFDC83C72 (c:\windows\system32\kernelbase.dll)
CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
00000000002BE9C8 000007FEFDC83C72 000007FEE8025860 000000000000EA60 00000000002BE928 00000000002BF030 kernelbase.dll!0x7fefdc83c72
00000000002BE9D0 000007FEE7E9D053 0000000000177200 0000000000177200 00000000002BF030 0000000000000000 obsapi.dll!OSTerminateThread+0x33
00000000002BEA00 000000013F892BE5 0000000001EF1400 0000000000000000 0000000000000000 0000000000000001 obs.exe!RTMPPublisher::~RTMPPublisher+0xb5
00000000002BEE80 000000013F892894 0000000000000003 0000000000000000 0000000000000000 000000013F88A234 obs.exe!RTMPPublisher::`vector deleting destructor'+0x14
00000000002BEEB0 000000013F88CFF2 0000000000000000 00000000002BF030 0000000000000401 0000000000000000 obs.exe!OBS::Stop+0x112
00000000002BEF30 000000013F8AC6E9 000000000000FF00 0000000000030000 0000000000000401 00000000002BF380 obs.exe!OBS::OBSProc+0x17f9
00000000002BF0C0 00000000778D9BD1 00000000002BF380 000000013F8AAEF0 0000000000A54790 0000000000A54790 user32.dll!0x778d9bd1
00000000002BF180 00000000778D98DA 0000000000000000 0000000000000000 000000013F8AAEF0 0000000000000001 user32.dll!0x778d98da
00000000002BF200 00000000778D67C2 0000000076C00621 0000000076C00621 000007FEFF852164 0000000000416C00 user32.dll!0x778d67c2
00000000002BF290 000000013F8814F9 0000000000000000 0000000000000000 000000013F860000 0000000000000000 obs.exe!WinMain+0x8b9
00000000002BF7C0 000000013F8F4D50 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!strstr+0x1ac
00000000002BF870 00000000779D652D 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x779d652d
00000000002BF8A0 0000000077B0C521 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x77b0c521
A minidump was saved to C:\Users\Gebruiker\AppData\Roaming\OBS\crashDumps\OBSCrashDump2013-08-12_1.dmp.
Base Address                      Module
  • OBSCrashDump2013-08-12_1.rar
matagyula
Got a crash today with 09. Attached the OBS Crash log and the dumpfile. I was streaming iRacing, running in a window. The stream was fine for more than an hour.
  • crashDumps.rar
  • 2013-08-14-1103-00.log
Kharay
Just attempted to stream MC again with .09 and just starting the stream in general seems to crash Java at the moment. Note, I am using OptiFine (mod for MC) which may in fact be part of the equation. But still, it didn't crash before (in .08).
vaesauce
Was streaming BF3 and crashed with the latest build.
Fault address: 000007FEFDAC3C72 (c:\windows\system32\kernelbase.dll)
OBS version: Open Broadcaster Software v0.54.09 network/gc test
CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
00000000002BEB78 000007FEFDAC3C72 000007FEE0165860 000000000000EA60 00000000002BEAD8 00000000002BF1E0 kernelbase.dll!0x7fefdac3c72
00000000002BEB80 000007FEDFFDD073 0000000001D52800 0000000001D52800 00000000002BF1E0 0000000000000000 obsapi.dll!OSTerminateThread+0x33
00000000002BEBB0 000000013FB22BE5 00000000001BF380 0000000000000000 0000000000000000 0000000000000001 obs.exe!RTMPPublisher::~RTMPPublisher+0xb5
00000000002BF030 000000013FB22894 0000000000000001 0000000000000000 0000000000000000 000000013FB1A224 obs.exe!RTMPPublisher::`scalar deleting destructor'+0x14
00000000002BF060 000000013FB1CFE2 0000000000000000 00000000002BF1E0 0000000000000401 0000000000000000 obs.exe!OBS::Stop+0x112
00000000002BF0E0 000000013FB3C789 000000000000FF00 0000000000030000 0000000000000401 00000000002BF558 obs.exe!OBS::OBSProc+0x17f9
00000000002BF270 0000000076E69BD1 00000000002BF558 000000013FB3AF90 0000000000C8B690 0000000000C8B690 user32.dll!0x76e69bd1
00000000002BF330 0000000076E698DA 0000000000000000 0000000000000000 000000013FB3AF90 0000000000000001 user32.dll!0x76e698da
00000000002BF3B0 0000000076E667C2 00000000000526E7 00000000000526E7 000007FEFE0F2164 0000000000000001 user32.dll!0x76e667c2
00000000002BF440 000000013FB11499 0000000000000000 0000000000000000 000000013FAF0000 0000000000000000 obs.exe!WinMain+0x8b9
00000000002BF9A0 000000013FB84E00 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!strstr+0x1ac
00000000002BFA50 0000000076D4652D 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x76d4652d
00000000002BFA80 000000007743C521 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7743c521
A minidump was saved to C:\Users\PC\AppData\Roaming\OBS\crashDumps\OBSCrashDump2013-08-15_1.dmp.
Base Address Module
Attachment won't WORK SPOEIFHPOSFHPSOEIFH
Gol D. Ace
Minecraft 1.6.2
64 Bit Java
01:21:50: Settings::Video: Enabling Aero
01:22:26: Open Broadcaster Software v0.54.09 network/gc test - 64bit ( ^ω^)
01:22:26: -------------------------------
01:22:26: CPU Name: Intel(R) Core(TM) i5 CPU         760  @ 2.80GHz
01:22:26: CPU Speed: 2809MHz
01:22:26: Physical Memory:  8183MB Total, 4725MB Free
01:22:26: stepping id: 5, model 14, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 4, total cores 4
01:22:26: monitor 1: pos={0, 0}, size={1280, 1024}
01:22:26: Windows Version: 6.1 Build 7601 S
01:22:26: Aero is Enabled
01:22:26: OBS Modules:
01:22:26: Base Address     Module
01:22:26: 000000003F640000 OBS.exe
01:22:26: 00000000EF9C0000 OBSApi.dll
01:22:26: 00000000F3CE0000 DShowPlugin.dll
01:22:26: 00000000F3C30000 GraphicsCapture.dll
01:22:26: 00000000FB940000 NoiseGate.dll
01:22:26: 00000000F4730000 PSVPlugin.dll
01:22:26: ------------------------------------------
01:22:26: Adapter 1
01:22:26:   Video Adapter: NVIDIA GeForce GTX 460
01:22:26:   Video Adapter Dedicated Video Memory: 758579200
01:22:26:   Video Adapter Shared System Memory: 3489214464
01:22:26: =====Stream Start: 2013-08-16, 01:22:26===============================================
01:22:26:   Multithreaded optimizations: On
01:22:26:   Base resolution: 854x480
01:22:26:   Output resolution: 852x480
01:22:26: Loading up D3D10 on NVIDIA GeForce GTX 460...
01:22:26: Playback device {0.0.0.00000000}.{72bcd744-d1f6-4bc1-97d1-085123b7db73}
01:22:26: Using desktop audio input: Lautsprecher (VIA High Definition Audio)
01:22:26: Using auxilary audio input: Mikrofon (VIA High Definition Audio)
01:22:26: Audio Encoding: AAC
01:22:26:     bitrate: 128
01:22:26: Using graphics capture
01:22:26: Video Encoding: x264
01:22:26:     fps: 60
01:22:26:     width: 852, height: 480
01:22:26:     preset: veryfast
01:22:26:     CBR: yes
01:22:26:     CFR: no
01:22:26:     max bitrate: 1600
01:22:26: MMDeviceAudioSource: Frequency for device 'Lautsprecher (VIA High Definition Audio)' is 352800, samples per sec is 44100
01:22:26: MMDeviceAudioSource: Frequency for device 'Mikrofon (VIA High Definition Audio)' is 384000, samples per sec is 48000
01:22:26: using memory capture
01:22:27: Using RTMP service: Twitch / Justin.tv
01:22:27:   Server selection: rtmp://live-lhr.justin.tv/app
01:22:27:   Interface: Realtek PCIe GBE Family Controller (ethernet, 100 mbps)
01:22:29: SO_SNDBUF was at 8192
01:22:29: SO_SNDBUF is now 65536
01:30:12: RTMPPublisher::SocketLoop: Aborting due to FD_CLOSE, error 0
01:30:12: Total frames rendered: 27951, number of late frames: 21 (0.08%) (it's okay for some frames to be late)
01:31:12: WARNING: Forcibly terminating a thread after 60000 ms timeout!
Fault address: 000007FEFD863C72 (c:\windows\system32\kernelbase.dll)
CPU: Intel(R) Core(TM) i5 CPU         760  @ 2.80GHz
000000000030EA38 000007FEFD863C72 000007FEEFB75860 000000000000EA60 000000000030E998 000000000030F0A0 kernelbase.dll!0x7fefd863c72
000000000030EA40 000007FEEF9ED073 00000000001D2000 00000000001D2000 000000000030F0A0 0000000000000000 obsapi.dll!OSTerminateThread+0x33
000000000030EA70 000000013F672BE5 00000000000FC620 0000000000000000 0000000000000000 0000000000000001 obs.exe!RTMPPublisher::~RTMPPublisher+0xb5
000000000030EEF0 000000013F672894 0000000000000000 0000000000000000 0000000000000000 000000013F66A224 obs.exe!RTMPPublisher::`scalar deleting destructor'+0x14
000000000030EF20 000000013F66CFE2 0000000000000000 000000000030F0A0 0000000000000401 0000000000000000 obs.exe!OBS::Stop+0x112
000000000030EFA0 000000013F68C789 000000000000FF00 0000000000030000 0000000000000401 000000000030F418 obs.exe!OBS::OBSProc+0x17f9
000000000030F130 00000000775A9BD1 000000000030F418 000000013F68AF90 0000000000A68690 0000000000A68690 user32.dll!0x775a9bd1
000000000030F1F0 00000000775A98DA 0000000000000000 0000000000000000 000000013F68AF90 0000000000000001 user32.dll!0x775a98da
000000000030F270 00000000775A67C2 0000000000DC1543 0000000000DC1543 000007FEFC78F450 0000000000000000 user32.dll!0x775a67c2
000000000030F300 000000013F661499 0000000000000000 0000000000000000 000000013F640000 0000000000000000 obs.exe!WinMain+0x8b9
000000000030F860 000000013F6D4E00 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!strstr+0x1ac
000000000030F910 000000007748652D 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7748652d
000000000030F940 00000000776BC521 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x776bc521
A minidump was saved to C:\Users\Ace\AppData\Roaming\OBS\crashDumps\OBSCrashDump2013-08-15_1.dmp.
Base Address                      Module
2013-08-16, 01:22:26: we're booting up:
01:22:26: NV Capture available
01:22:26: FBO available
01:22:26: GL Present
01:22:26: (half life scientist) everything..  seems to be in order
01:22:26: SwapBuffers(402720711) Called
01:22:26: setting up gl data
01:22:26: DoGLCPUHook: success
01:22:26: wglSwapBuffers(402720711) Called
01:22:26: successfully capturing gl frames via RAM
01:30:12: stop requested, terminating gl capture
01:30:12: ---------------------- Cleared OpenGL Capture ----------------------
01:30:12: wglSwapBuffers(402720711) Called
01:30:12: setting up gl data
01:30:12: SwapBuffers(402720711) Called
CrashDump file: http://puu.sh/437R1
Status
