Adding notifications when you start recording in OBS Studio
Zerobyte
My idea is, whenever you usually record on obs right now, it doesnt show any notification if its recording right? If you want to see if it is recording, you've gotta check your taskbar to see if it has the red dot on the logo. Now all im saying is is that i accidentally record sometimes and i would love it if you add notifications when you start recording and when the recording stopped.
Just a suggestion, nothing special.
I've been wanting to get notifications from OBS for a long time, but I haven't found any solutions. So I developed OBS Notifier.
It uses obs-websocket 4.9.1, and there is also a modified version of it with replay support. Works only on Windows.
Download: https://dmitriysalnikov.itch.io/obs-notifier
how do i set it up? it's kinda complicated for me
In short, you just need to install the obs-websocket plugin and download OBS Notifier.
And here is a more detailed guide:
1. Download and install obs-websocket from the links at the bottom of this page: https://github.com/obsproject/obs-websocket/releases/tag/4.9.1
2. Enter a new password for the websocket server
3. Download and unpack OBS Notifier: https://dmitriysalnikov.itch.io/obs-notifier or https://github.com/DmitriySalnikov/OBSNotifier/releases/latest
4. Run OBS Notifier (you may need to unlock the file, but this is usually not required)
5. In OBS Notifier, enter the previously specified password and click Connect
That's all you need for almost all available notifications to work.
To show notifications about saving replays, you need to copy and replace obs-websocket.dll from the custom_libs folder to the /obs-plugins/64bit/ folder where obs is installed.
Now you will be able to see notifications about saving replays
1) Audio Notifications would be a great feature. I can set them up with the Advanced Scene Switcher; but a simpler method would be nice.
2) The nVidia overlays have never triggered any anti-cheat measure. Have you tested it or is it only an assumption that yours would?
This is an assumption, a concern, and a warning. There is no guarantee that some anti-cheat will suddenly ban you or not.
Since the program does not integrate into the game processes at the moment, this is not a problem. I have been playing with my program for a long time and have not received any bans for using it.
But without a digital signature, I will not be able to integrate into the processes of games and ensure that you will not be banned.
Both Nvidia overlays and drivers, this is a slightly completely different question. They have digital signatures and direct interaction with developers of operating systems, anti-cheats and games.
This has already been planned for future updates.
