Adjustment Layer
Adjustment Layer 1.1.0
i'm not a programmer, so I am only guessing. My virtual assistant had me try to manually install it, but I didn't see the . so file. However, I saw the data file. Maybe this will help. Thanks.
Hi Horaiken 1.0.5 Their was a load error. Same as last version for the Mac by Stream up. "adjustment-layer ⚠️ Failed to Load Not Supported OBS Forums" Thank you for all your efforts. Prayerfully next update?​
Ah, could it be that you’re using an Intel-based Mac?
I’ve been developing this for Apple Silicon, so that might explain the issue.
Awe.. I should have mentioned that I'm using an intel Mac. Unfortunately an upgrade in computers is not financially possible right now. Someday.....Thanks.
Awe.. I should have mentioned that I'm using an intel Mac. Unfortunately an upgrade in computers is not financially possible right now. Someday.....Thanks........any possibility it will be available for Intel Mac in the future? I don't know what the differences are in coding and how hard it is to do, so I don't know. Thanks.
Hi Horaiken, As mentioned before, I'm a non programmer. I don't know what is involved in developing this software. If it's a lot of work or not, but I'm wondering if you have any plans to make it available for intel Macs in the future. It really looks great! Thanks.
Hi Horaiken, I'm still on a Mac, , but I installed Win 11 virtually. Adjustment layer successfully installed and I am able to add it as a source, but I don't see the options you show in your video unfortunately. Wondering what I'm doing wrong or it might still be my intel Mac? Any help would be appreciated. Thanks.
Horaiken updated Adjustment Layer with a new update entry:
Fix: Prevent deadlocks and GPU crashes during scene destruction
This release fixes critical freezing and crashing issues that occurred when creating or deleting the Adjustment Layer, particularly on Windows and when used alongside specific other plugins.
本リリースは、特定の環境下(Windowsや他のプラグインとの併用時)において、調整レイヤーの作成・削除の際にOBS全体がフリーズまたはクラッシュする問題を修正するバグフィックスリリースです。
Bug Fixes
Fix GPU driver crashes and freezes on layer removal (especially on Windows/D3D11)
  • Deleting the...
CAN YOU PLEASE mention somewhere that this is not for intel macs? I was hoping when you updated it this time it would be intel compatible. I loaded it and it did not load as previous version. Not trying to be mean, but am really fascinated by it and would like to use it. Thanks!
Update: Add show/hide transition support and improve rendering stability
This release adds support for source show and hide transitions and improves the overall stability of the Adjustment Layer. It also prevents unsupported placements from causing unexpected behavior by displaying a clear warning instead.
本リリースでは、ソースの表示・非表示トランジションに対応し、調整レイヤー全体の安定性を向上しました。また、未対応の配置による予期しない動作を防ぎ、代わりに分かりやすい警告を表示するようにしました。
New Features​
  • Sources below the Adjustment Layer now correctly use their configured show and hide transitions...
